Bearing lubrucation
Old Jan 4, 2020 | 02:43 PM
carbon1993's Avatar
carbon1993
Default Bearing lubrucation
Hi folks, i have question about plain bearing lubrication. I adapted the ignition distributor because it is taking up too much space and is pretty much in the way of the supercharger piping.
The question is should i make some holes in the bushing/bearing so it gets lubed?
As you can see theres is a spiral that pumps oil down. The spiral is pretty scored as some caked up oil blocked the route.
the car makes some whining noise wich seems to come from the ignition distributor. I think its the bearing.
Old Jan 6, 2020 | 04:07 AM
Stroker's Avatar
Stroker
10 Year Member
My not just run one of these and just swap over the bottom gear for the 2.8 one? Not 100% sure it'll fit but they're cheap enough to try. Will give you the option to go sequential at a later date if you desire.
http://www.rockauto.com/en/moreinfo....62451&jsn=2466
Old Jan 6, 2020 | 05:17 PM
carbon1993's Avatar
carbon1993
Thanks! could have been a very good solution! Too bad they only have the 2.9 drive on those. I have the hexagon patterned one.
Old Jan 7, 2020 | 06:43 AM
Stroker's Avatar
Stroker
10 Year Member
My not just run one of these andjust swap over the bottom gear for the 2.8 one? Not 100% sure it'll fit but they're cheap enough to try. Will give you the option to go sequential at a later date if you desire.
Can't you change the 4.0 gear drive to the 2.8 gear drive??
Old Jan 9, 2020 | 10:59 AM
carbon1993's Avatar
carbon1993
The problem is in the oil pump intermediate shafts. Not the actual gears.
Old Jan 25, 2020 | 06:52 PM
stevieturbo's Avatar
stevieturbo
C**t
Machine the housing and install a needle roller ?
Fernando_221
Jul 18, 2019 01:06 PM
blacky.
20
Oct 14, 2008 10:47 PM
Chip
Aug 13, 2007 01:57 PM
rickyboy
Nov 20, 2004 01:01 PM
