MTX75 rebuild help
MTX75 rebuild help
Hi!
I'm starting a rebuild of my MTX75 gearbox, I'll replace bearings and the final drive ratio (ring gear and output shaft). I'm stuck trying to remove the 3rd gear from the output shaft. Any tips?
I managed to remove the rear bearing, 4th, 5th and reverse gears from the output shaft with a pulley puller and hydraulic press. I couldn't find any way to hold the 3rd gear in the hydraulic press. Do I need to press out 2nd and 3rd gear together?
Hello,
Did you get the 2nd and 3d gear off the shaft? How did you solve it?
I stuck at same place, trying to pull of 2nd and 3rd gear together off and it doesn´t work. Even with inductor heating up the gears there´s no movement at all.
Advice needed. Please!
RAT8OY
26-01-2010 06:42 PM
