Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Xr2i Rev limiter
Old Dec 5, 2019 | 07:36 PM
W4rdy's Avatar
W4rdy
Default Xr2i Rev limiter
I have an xr2i race car. I am having an intermittent misfire but i feel like it’s actually the limiter momentarily cutting in rather than a mis.
I changed plugs leads coil pack etc to rule all this out. My question is... what tells the Ecu the engine revs? Crank position sensor?
what other things could it be?
tps? Edis?
running an after market ecu not ever had problems before this.
any other suggestions?
Thanks
Old Jan 30, 2020 | 11:06 AM
XR2's Avatar
XR2
Who fitted the aftermarket ECU? This person should know which signals are used!? Usually it's at least CPS, some also combined with a camshaft sensor.
Misfiring can have a lot of reasons. Wrong amount of fuel, wrong plugs, wrong leads etc. Oh and early EDIS were standalone systems... So it CAN be a rev limiter although you have an aftermarket ECU fitted.
Old Jan 30, 2020 | 05:49 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
tps? Edis?
Thanks
TPS is a suspect the crank sensor tells ecu engine speed , i`d say try a multi meter on tps
JoeyBoyden
Jan 18, 2016 08:21 PM
Stu @ Claims Care Centre
Apr 13, 2009 07:39 AM
scoooby slayer
Jun 23, 2007 10:50 AM
leonpascoe
Nov 1, 2006 08:56 AM
danxr2i
Jun 7, 2005 10:33 PM
