Urgent Help Needed Please
Old Nov 17, 2019 | 04:12 AM
paulee's Avatar
paulee
Default Urgent Help Needed Please
Hi all , my daily driver has just started acting up and i am totally stumped.
Took my egr valve off my 2010 tdci astra estate , gave it a good clean and now my car wont start.
Its turns over but its a different noise when turning the key (sounds well different can tell somethings not right so turn it off straight away)and wont fire up then when i remove the key the egr valve is clicking plus a humming noise.(might not be related to it not starting)
I have re done everything A million times checked wires etc spent 8 hours yesterday on it and have just fully charged the battery.still nowt.
I am worried the black carbon soot has fell into the engine ( some one please say this isnt poss! lol )
Anyway i have to get my kids to school tomoz so all help is super appreciated cheers.
Old Nov 17, 2019 | 06:52 PM
slammedorion's Avatar
slammedorion
Put a new egr valve on or blank it off...
Sounds like your current egr is jammed...
Old Nov 18, 2019 | 07:39 AM
paulee's Avatar
paulee
Thanks mate , ive totaly took it apart spring and all and it moves freely i even wired it up and saw it move.My mechanic was saying it should still fire up without the egr.
I spent ages again checking i know i have compression , fuel from injectors , glowplugs ok , battery ok , starter working , belts working ,maf didnt affect it, going to try bump it later might be with my no compression 10 minute start on the cold start vavle escort lol 2 cars that half work :@ fs
Old Nov 18, 2019 | 08:53 PM
gcfcos's Avatar
gcfcos
If you've cleaned it then sometimes they need re-learning for closed position as it was would have been used to closing in a different position with carbon build up. Can reset it with a diagnostic scanner.
Old Nov 30, 2019 | 04:40 PM
paulee's Avatar
paulee
Nice one that would explain why it still does the clicking noise even though i got the car working with a bump cheers.
Old Dec 6, 2019 | 12:55 PM
gcfcos's Avatar
gcfcos
No probs. Hope it works
joshsparkes
Ford Focus (All Models)
Feb 15, 2014 03:49 PM
RiggerWrigley
25
Jan 3, 2013 11:58 AM
Mylo
Ford Focus Diesel
Apr 28, 2012 09:08 AM
havv
Nov 5, 2007 01:52 PM
gus
Dec 26, 2006 11:17 AM
