Dump valve removal chatter etc
Back in the day we used to remove blank dump valve, fit cone filter for the most awsome chatter noise
i remember ppl used to say kills turbos never harmed ours
so mine on greens with t34 With .48 housing
has a std airbox and aftermarket dump valve
set up by msd couple year back
can I still fit cone filter and do this?
not keen on dump valve noise to be honest
had this set-up for past 15 years and it works fine.
Before I got my Group A airbox the cone filter did make a quite loud "chatter" noise. Any Cone filter will be the same although it's nothing like the loud noise from a dump valve.Most people like the sound it makes with a cone filter or a drilled out flat airbox.
Forgot to say the size of the hose from your turbo to the cone filter will depend on the size and make of it. If you buy one just tell them what turbo you have and the company you buy it from will supply the correct size hose to the cone filter.
When I changed mine to stage 3 I put a standard airbox back on as old filter was knackered (and blanked dump valve) it felt like the car was choking and holding back.
So i put a group A cone filter on, car was much better and chatter seems pretty loud now.
Been running mine with blanked off dump valve and group a filter for over 13 years now and old t3 is still holding up ok. Lovely chatter noise I wouldn't want to lose that.
That is the only thing with my group A airbox it does make the sound of the turbo/cone filter much quieter.
snow*
Oct 22, 2006 11:23 PM
