36-1 trigger wheel on the original pulley crank
Old Nov 10, 2019 | 10:37 AM
shark91's Avatar
shark91
Default 36-1 trigger wheel on the original pulley crank
Hello I would like to know if someone has already mounted this sold by bhp or anembo.
The signal is done well?
I have a pulley of ggr aluminum and one of origin. It annoys me to buy a pulley if this alternative exists.
Thank you for your feedback
Old Nov 12, 2019 | 03:27 PM
R4N SS's Avatar
R4N SS
ive used the original pulley from an escort cosworth
Old Nov 13, 2019 | 11:18 AM
20/20 vision's Avatar
20/20 vision
From: it's not where you are, it's where you've been and where you hope to be
i'm not sure from your post whether you are considering buying an after-market pulley but be aware that some aftermarket 36-1 pulleys have the missing tooth in a different position relative to the woodruff key slot.
Old Nov 13, 2019 | 12:49 PM
timsrs's Avatar
timsrs
I’ve got an alloy pulley set for sale
crank with a 36-1 which can be changed for standard by unbolting 4 bolts
alternator pulley
power steering pulley
water pump pulley
Ł300 delivered
Old Nov 13, 2019 | 10:05 PM
Ridgey's Avatar
Ridgey
I got one, drilled and tapped the pulley to fit in the position I wanted the missing pin.
setup with Link ecu, needed a little research on where to have the missing pin roughly.
ptgladstone
12
Jan 29, 2016 09:26 AM
cutch
23
Jul 21, 2011 09:47 PM
Franco
32
Jul 25, 2006 07:05 PM
CosRush
Mar 10, 2006 11:43 AM
