Small crank pulley
How the fuck do you get it off!!!!
I want to change the gasket behind the plate but i'm fucked if i can see how to get it off without fords SPECIAL TOOL!
Originally Posted by Franco
What if you havent got a puller small enough!
mines too big........
http://www.machinemart.co.uk/product.asp?p=040211223
Unless i missed something?!?!?
The pulley i have is the big 3 legged puller.
Its not easy to tell from the pix but how much room is there underneath the pulley???
enough to get a head of a ground down HT bolt???
perhaps an M6 which could sit between the teeth in the recess keeping it close to the pulley body.
Just wondering if you could grind the heads to make them fit into the available space, then with them screwed into some steel with a central bolt, it may be enough to prise it off.....
but only if there's enough room.
Have a peek mate, if you have stick whatever you dont need in the post & i'll square you up another slapup feed in the cafe!
I'll be smashing shit out of tonight!![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Originally Posted by Stu @ M Developments
Worst case scenario:
Order a new cover from a breaker.
Split the old cover with a chisel.
Use puller to remove pulley.
Job done. 5mins. Simple.
Just dont smack the pulley itself by mistake
Yes i did thanks dude.......
Went for Stu's choice of the good old chisel option........ and smashed the livin bejesus out of it!
Then i could get the 3 legged puller on the pulley!
I think there would be only 2 options.........
you borrow one from Ford (if you know somebody who works there and they have one....)
or
you make one..............
or
timsrs
22
24-09-2015 08:14 PM
