Ive just changed my radiator on my 3 Door Cosworth for an alloy one and was thinking of doing the same for the Sapphire as temps run a lot less.
But, I have Air Conditioning in it so is this still a straight swap or is it more of an issue due to the air con?
Its a 1993 4x4 Sapphire Cosworth btw
I believe you could fit an uprated rad and still retain the a/c as long as you're on the stock 4x4 intercooler. I'm talking about the normal cores not the thicker ones though as I don't know whether those fit or not. If in doubt you could always measure the dimensions of the stock rad and the uprated rad and compare them. If they're fairly similar they should be interchangeable
Yes still on stock intercooler.
Will have to look and try to measure up.
I want to update the cooling and keep the air con so I get the best of both
My sapphire 4x4 cosworth has uprated radiator with std intercooler and a/c. Yes, it's straight fit. The only thing that you have to do is to adjust a/c radiator to engine radiator. It's not big job, just need some small brackets.
Thanks for the info.
What do you mean by adjust a/c to engine radiator?
I've wondered about the gas....can you use modern gas in these 90's cars??
I got told that you have to change the air con pump seals before putting the air con gas in. The gas used to be call 134r but I'm sure it's called something else these days.
I’m sure you used to be able to get an uprated radiator and inter cooler set up that retained the aircon. Think it may have been from pro alloy. I looked into it before I binned my aircon
