Sapphire radiator upgrade question
Ive just changed my radiator on my 3 Door Cosworth for an alloy one and was thinking of doing the same for the Sapphire as temps run a lot less.
But, I have Air Conditioning in it so is this still a straight swap or is it more of an issue due to the air con?
Its a 1993 4x4 Sapphire Cosworth btw
Heres a pic of my J reg 4x4 when i picked it up....it has a rs500 style intercooler and the ali rad.
The aircon had been deleted to fit this setup apparently.
Hope this helps to give you an idea what it looks like compared to your setup.
Thanks for the pics mate.
Looking to keep my air con tho
I believe you could fit an uprated rad and still retain the a/c as long as you're on the stock 4x4 intercooler. I'm talking about the normal cores not the thicker ones though as I don't know whether those fit or not. If in doubt you could always measure the dimensions of the stock rad and the uprated rad and compare them. If they're fairly similar they should be interchangeable
Will have to look and try to measure up.
I want to update the cooling and keep the air con so I get the best of both
My sapphire 4x4 cosworth has uprated radiator with std intercooler and a/c. Yes, it's straight fit. The only thing that you have to do is to adjust a/c radiator to engine radiator. It's not big job, just need some small brackets.
What do you mean by adjust a/c to engine radiator?
jessford@rocketmail.com
24-06-2011 02:24 PM
philg12
27-05-2011 03:56 PM
g10ens
18-07-2010 09:34 AM
