cosworth running fault
Old Jul 6, 2019 | 03:51 PM
killa_paul's Avatar
killa_paul
Default cosworth running fault
Hi all I've just had my 2wd sapphire live mapped at Norris motorsport . driving back it was 100% a week or so later I took it out and as soon as I hit the boost the turbo in 1st 2nd sometimes 3rd gear the car accelerates then dives forward as if you turn the ignition off and then comes back on if you try to drive tough it just kangaroos violently , its not a misfire as 4th and 5th are fine .
as I had an aftermarket petrol tank on the car to run it in and understood that the metal swirl pot type aftermarket tanks suffer from surging . I got hold a genuine group n Cosworth rally tank and fitted it , took it out and its still the same. I filled the tank too the brim which would top any surging issues from low level fuel pickup issues, Id think its the tank but I have now tried two different tanks ,
its almost like pulling off the map sensor vacuum hose briefly and putting it back on the car just dies . its only on hard acceleration if you drive slowly through second gear it does not do it ,
has anyone got any ideas what to check, its got new plugs , checked all hoses , the map sensor has own feed from the inlet separate from the boost gauge .checked all connections , its a nloom and sensors only done 1000 miles
help please
Old Jul 8, 2019 | 04:33 PM
bigdel's Avatar
bigdel
If it's just been mapped why not take it back to whoever mapped it?
Old Jul 8, 2019 | 05:28 PM
2Litre's Avatar
2Litre
Second that, don't mess with it. Call your mapper, might be able to point you in the right direction over the phone. If not send it back to be looked at.
Tim.
Old Jul 9, 2019 | 12:22 PM
martysmartie's Avatar
martysmartie
You are hitting a 'hard cut' as the boost pressure is most likely in excess to whatever the predetermined value is in your calibration.
Martin
Old Jul 9, 2019 | 07:56 PM
killa_paul's Avatar
killa_paul
Norris motorsport mapped it , and there miles away, I'm going to call him tomorrow and see what he says , the car has a boost controller so its all set to what he set it too when he live mapped it
but I will call him just wondered if you had any ideas before hand
Old Jul 12, 2019 | 07:21 PM
I would defo take it back to them to sort it.
Old Feb 27, 2023 | 09:08 PM
TVRVixenYB's Avatar
TVRVixenYB
Hi killa paul, did you manage to get your turbo cut out issue solved? And what was the culprit? I am having the exact same issue with my Cossie YB. Any informaiton pointing to the culprit would be greatly appreciated. Thank you.
Old Feb 27, 2023 | 09:18 PM
james kiely's Avatar
james kiely
sounds like a hard ignition cut caused by too much boost
Old Feb 27, 2023 | 09:21 PM
TVRVixenYB's Avatar
TVRVixenYB
Thank you, much appreciated.
Jonny5H
Ford Mondeo Including ST
May 6, 2014 10:13 AM
drsrst2zvh
12
Nov 14, 2010 10:24 AM
rs kyle
May 6, 2010 08:58 PM
jammy86
Jul 20, 2008 10:21 PM
JonnyBravo
Feb 7, 2006 10:15 PM
