Ford ids
Old Jun 26, 2019 | 12:02 PM
Transitscott's Avatar
Transitscott
Default Ford ids
Hi people having trouble programming a fuel pump on my 55 plate transit i start new session do a self test then I go to body>security>pats> module initialization>fip>incode then it starts to clear rim then turn the key on and off then it says incomplete please someone tell me where I am going wrong as I need the van for work and I won't have a job if not done by tomorrow
Old Jun 26, 2019 | 06:59 PM
GVK.'s Avatar
GVK.
where have you got your codes from?
Old Jun 26, 2019 | 07:04 PM
Transitscott
Autokeyprog I got the incode from there the first time it said module reset compete but after that it says incomplete after it clears rim
Old Jun 26, 2019 | 07:13 PM
GVK.'s Avatar
GVK.
Sorry not familiar with autokeyprog, have only ever got codes from Ford through etis, I read your other thread https://passionford.com/forum/genera...-ids-help.html and it seems as though you followed the right steps.
Old Jun 26, 2019 | 07:21 PM
Transitscott
I thought so but it doesn't work just wondering if I've missed something along the way
Old Jun 26, 2019 | 07:24 PM
GVK.'s Avatar
GVK.
The other thing is I've only ever fitted new pumps, but in theory when it does the clearing rim part it should clear an old pump.
Old Jun 26, 2019 | 07:48 PM
GVK.'s Avatar
GVK.
Might be worth asking on https://fordtransit.org/
I know it takes about 10 mins usually to clear the RIM, how's your battery voltage. Might be worth doing it with a charger on the battery.
As it's said it's incomplete I'm not sure whether you can re-use the incodes more than once?
Old Jun 26, 2019 | 10:13 PM
GVK.'s Avatar
GVK.
Me again lol.
I asked a mate I used to work with, he had similar once there is a 3 or 5 amp fuse in the engine bay fuse box that can blow to cause this also check wiring to pump he said.
Also make sure numbers on pump match as if they don't it's no good.
Ljames555
18
Feb 6, 2019 07:17 PM
nmca
Apr 11, 2013 05:56 PM
actionman
Aug 1, 2012 11:07 PM
b_kennedy
Jul 14, 2009 05:32 PM
andrewg
Nov 21, 2008 09:20 AM
