Rs Turbo psi
Old Jun 3, 2019 | 04:20 PM
BlakeMoyle's Avatar
BlakeMoyle
Wish I had more time!
10 Year Member
Default Rs Turbo psi
Hi there,
was wondering whats the safest boost level to run on my s2? When I bought had a stage 1 turbo and stainless manifold and exhaust, a half mount Intercooler but no chip? The chap must of been having the intentions to do so! I’ve had the car chipped and it’s boosting about 7-8psi. Still has the Amal valve fitted and want to keep if possible so how does one go about upping the boost a little?! Thanks in advance! Internals are all standard from what I know.
Old Jun 3, 2019 | 05:12 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Originally Posted by BlakeMoyle
Hi there,
Anyone please?!
Old Jun 3, 2019 | 05:31 PM
studabear's Avatar
studabear
Chipped ecu and then take it to a tuner to be set up. You want a tuner that is experienced with the mfi system.
Old Jun 3, 2019 | 05:54 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Hi thanks for the reply, the car has had a chipped Ecuador’s fitted already, I was curious what level of boost it could run at that spec and how to achieve that level of boost without ripping the Amal valve out and replacing with a bleed valve?
Old Jun 3, 2019 | 05:55 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Ecuador’s?! ECU! 😂
Old Jun 3, 2019 | 06:21 PM
studabear's Avatar
studabear
I think it will be mainly determined by how good the mfi system is and the engine condition. It needs setting up properly otherwise it can all go horribly wrong.
Where do you live?
Old Jun 3, 2019 | 06:23 PM
Bullrst's Avatar
Bullrst
Unless it has a -31 actuator you wont get much higher boost than what you are currently getting.As other poster said bring it to tuner to get set up on rolling road it’ll give you piece of mind and will save your engine from crapping itself if you go adjusting boost levels without fueling to match...Ł70 is alot cheaper than a rebuild
Old Jun 3, 2019 | 06:31 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Thanks for the replies, I live in Bath so need to do some research as to where I can take it? Msd is along way from home! I think I’ll get a -31 fitted and find a tuner like you say.
Old Jun 3, 2019 | 06:35 PM
Bullrst's Avatar
Bullrst
You wont regret it,get a boost gauge fitted as well if you haven’t already its another way of making sure its boosting correctly
Old Jun 3, 2019 | 06:41 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
I have a boost gauge was given to me by a friend it’s a tiny little thing from a Subaru, I didn’t want anything too big it reads in cm2 holding 0.5cm2 which according to the web is about 7psi, I think the set up would do it the world of good, just need to find somewhere now! 😂
Old Jun 3, 2019 | 06:59 PM
Bullrst's Avatar
Bullrst
7psi is healthy boost for good 130/140 bhp provided engines healthy 👍
Old Jun 3, 2019 | 07:22 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Thanks for all your replies, I will get it to a tuner and hopefully will make a lot more with the mods that are on it! 😂👍🏼
mhs
Feb 20, 2011 09:30 AM
Joe91
Jan 10, 2011 09:01 PM
scoooby slayer
30
Oct 4, 2007 07:13 PM
wentyno1
Sep 28, 2006 04:04 PM
turboash
Mar 11, 2006 05:55 PM
