turbo boosting 2 psi ???
have just fitted a second hand turbo unit and it is only boostin 2 psi, i changed over my actuator but didnt adjust the rod or anything, , , any ideas ???
no have by passed it, was running 10psi before cant understand why just changing the actuator over to the new unit would make a differance
is it the same actuator as u had? If the bracket is in a slighlty different position, it will alter the boost, it only needs to have moved a tiny amount.
adjusted the actuator rod this afternoon until car was boostin near enough same as before, will take it to my local tuner to make sure it is setup correctly..
thanks for the advice
Matt Baxter
16-09-2015 08:30 PM
Indyrs
20
01-09-2015 09:04 AM
gchristophi
31-08-2015 10:36 PM
