ford coolant temp curve
Old Apr 13, 2019 | 10:02 PM
carbon1993's Avatar
carbon1993
Default ford coolant temp curve
Does anyone have a temp sensor curve for a ford coolant sensor. The one that sits on sierra escort granada etc. I need to fill in a curve for my ECU.
thanks kind regards,
michael
Old Apr 13, 2019 | 10:08 PM
bigdel's Avatar
bigdel
What ecu are you using?
If it's an Omex, their support team will supply you with a calibration for the standard Ford sensor
Old Apr 14, 2019 | 09:05 AM
carbon1993's Avatar
carbon1993
I am using a Vems ecu. There is only one that i can choose and thats an standard bosch. And that sensor wont fit in my cooling pipes.
A chart with volts and temps would be usefull to make it work
Old Apr 14, 2019 | 08:32 PM
4x4kiwi's Avatar
4x4kiwi
Don't know if it would be any use to you but on http://www.bigturbo.co.uk/ there is a table on the sensors tab of temp vs resistance of the sensor. This is used in a voltage divider network to provide a voltage to the ECU. If you know the value of the other resistance used in the divider network, you could use ohms law to come up with a voltage vs temp table.
David.
olic1
Jan 31, 2009 01:38 PM
Martin-Hadland
15
Jun 20, 2008 05:29 PM
cng1
Aug 22, 2004 08:36 PM
