S2 ERST 2.1 ZVH FLYWHEEL HELP.... !!
Old Apr 13, 2005 | 02:33 PM
glenis's Avatar
glenis
Default S2 ERST 2.1 ZVH FLYWHEEL HELP.... !!
where can i get a BRAND NEW fly wheel for a 2.1 ZVH ERST.....
where from ? and prices ?
any help would be fantastic, thank you !!
Old Apr 29, 2005 | 04:31 PM
white cab's Avatar
white cab
use a rs cvh one and drill the 6 mounting bolts out to 11mm
Old Apr 29, 2005 | 05:06 PM
glenis's Avatar
glenis
needs to be EFi though
for crank sensor i think
Old Apr 29, 2005 | 05:12 PM
white cab's Avatar
white cab
sorry you didnt state which one
what managment are you running?
Old Apr 29, 2005 | 05:14 PM
glenis's Avatar
glenis
sorry, it was my fault
Car is running L8 management from a 4x4 sapphire...
Old Apr 29, 2005 | 05:23 PM
white cab's Avatar
white cab
well you only need to run only 4 pick ups so there is no need for the efi wheel you may want to use the original crank sensor and just machine the pick ups into the wheel take it to a machine shop and have pegs put in it.
i think it is more work converting an efi wheel tbh.
Or just mount the cranks sensor on the oil pump and weld the pick ups on the altenator pully
Old Apr 29, 2005 | 05:26 PM
glenis's Avatar
glenis
actually thinking about it
i was looking at my alternator pulley wheel the other day, and noticed it had thread pegs welded to it, 4 of them... that are kinda stuck out of the edge of the pulley wheel...
does that mean the crank sensor on my car, is not even on the flywheel
Old Apr 29, 2005 | 05:29 PM
white cab's Avatar
white cab
the problem is if you are changing to zvh you will have to make a new bracket to mount the cps onto as the oil pump bolt holes on the zetec are different to those on the cvh.
Old Apr 29, 2005 | 05:32 PM
glenis's Avatar
glenis
the is already a ZVH... bottom end is obviously Zetec...
i dont quite understand why you say "if i was changing to ZVH"
Old Apr 29, 2005 | 05:35 PM
white cab's Avatar
white cab
i assumed that you were changing from a cvh to zvh what are you trying to do exactly
Old Apr 29, 2005 | 05:38 PM
glenis's Avatar
glenis
the car is running a ZVH motor at present...
and the flywheel is badly worn and needs replacing, but i was told i should only fit a flywheel from a EFI CVH car...
but now i think i dont need to, as my crank sensor is not reading off the flywheel
i was looking at my zetec (ZVH) alternator pulley wheel the other day, and noticed it had thread pegs welded to it, 4 of them... that are kinda stuck out of the edge of the pulley wheel...
Old Apr 29, 2005 | 05:40 PM
white cab's Avatar
white cab
is there a sensor there which is just off the pully conected to the main loom
Old Apr 29, 2005 | 05:42 PM
glenis's Avatar
glenis
there could well be, i need to have a closer look
all i know is, i remember seeing the alternator pulley with strange lugs welded to it...
and after what you said, that made me think, it could be for the crank sensor
Old Apr 29, 2005 | 05:45 PM
white cab's Avatar
white cab
if the flwheel is worn why dont you get it refaced and if the ring gear is worn just fit a new one
Old Apr 29, 2005 | 05:47 PM
glenis's Avatar
glenis
i dont know how to get it refaced...
or where to... or even what it involves...
Old Apr 29, 2005 | 05:55 PM
white cab's Avatar
white cab
if the face is fooked cos of the paddle clutch you are most probally using either take it to a machine shop and get it skimmed in a lathe till the surface is as new but dont take too much off!
Old Apr 29, 2005 | 05:57 PM
glenis's Avatar
glenis
wouldnt it be easier to just get another one, in good condition and bolt that on instead ?
top advice so far though, thank you
Old Apr 29, 2005 | 06:03 PM
white cab's Avatar
white cab
it is up to you i would pull the dowel pins out in a vice and just take it to my local engineering workshop who will put it in a 4 jaw chuck and clock it up and skim the face off for about £10 i have done it myself as i have acces to a lathe piece of pi$$ to do though!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
Mc5506
Oct 5, 2015 09:57 PM
davidfordrs
Sep 21, 2015 04:23 AM
