cossie manifold common fault
Old Apr 13, 2005 | 02:31 PM
cossiecrew's Avatar
cossiecrew
Default cossie manifold common fault
well pissed off my old mans manifold had cracked on his 4x4 inside where the turbo bolts to it and someone off here pmd me saying he had 1 so i sent the money got it today and guess what a crack in the same place im well pissed about it as i asked if it had any cracks before paying and was told non att all otherwise i wouldnt of brought it so it must be a common thing on 4x4s so next time ya turbos off take a look
Old Apr 13, 2005 | 02:40 PM
Disabled Account's Avatar
Disabled Account
Default Re: cossie manifold common fault
Yes, cracks are very common on 4x4 exhaust manifolds......cant recall seeing one without any cracks TBH So just a question of avoiding badly cracked ones
Old Apr 13, 2005 | 02:43 PM
cossiecrew's Avatar
cossiecrew
if i get an uncracked 1 whick i will how do i prevent it from cracking what about a spec r turbo damper they any good ?its got a t34 if that makes any difference to it fitting
Old Apr 13, 2005 | 02:49 PM
xr4x4rs's Avatar
xr4x4rs
mines cracked
so going either 2wd or tubular now on my new one
with a damper
hard to get one thats not cracked try martin at reyland
he may have one
Old Apr 13, 2005 | 02:51 PM
cossiecrew's Avatar
cossiecrew
ive got another turning up tommorow and ive payed good money for it so if its cracked someones getting a visit
Old Apr 13, 2005 | 02:53 PM
xr4x4rs's Avatar
xr4x4rs
but get a damper anyway
cus it will save your head studs snapping
i had 5 studs sanpped in mine when i took it off
Old Apr 13, 2005 | 02:55 PM
cossiecrew's Avatar
cossiecrew
lol his had 1 so whats the best damper around to fit t34 on a 4x4
Old Apr 13, 2005 | 03:00 PM
xr4x4rs's Avatar
xr4x4rs
i ordered a sepc-r one
its a big hchunky block not the 3 pronged one like bailey
this is designed for that but bloody expensive
didnt need it after that cus going different manifold and just sold it about a month ago on ebay
but that would be the best bet
Disabled Account
If you are going to get a damper anyway, then why not use a 2WD manifold instead of the 4WD one? The 2WD item is better for big power and there are 2 or 3 dampers designed for it.........
Old Apr 13, 2005 | 03:02 PM
SapphyMike's Avatar
SapphyMike
4wd exhaust manifold means you dont need a damper.. i dont think a damper will fit.
Old Apr 13, 2005 | 03:04 PM
cossiecrew's Avatar
cossiecrew
they wont fit 4x4s why not
Old Apr 13, 2005 | 03:05 PM
xr4x4rs's Avatar
xr4x4rs
adamper will fit spec-r do one
4wd manifolds are worse for cracking than 2wd
but a 2wd is better if u want big power etc
Old Apr 13, 2005 | 03:07 PM
cossiecrew's Avatar
cossiecrew
but its not just a case of changing the manifold is it theres other things involved aint there right im goin in search of a spec r 1
Old Apr 13, 2005 | 03:10 PM
xr4x4rs's Avatar
xr4x4rs
here u go mate website and pic of what it looks like
http://www.spec-r.co.uk/
Old Apr 13, 2005 | 03:11 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
makes me laugh,I have 2 un cracked ones sitting here 20 mins away from you and you shop elsewere and buy rubbish
Old Apr 13, 2005 | 03:14 PM
cossiecrew's Avatar
cossiecrew
have emailed spec r just waiting for reply
Old Apr 13, 2005 | 03:15 PM
xr4x4rs's Avatar
xr4x4rs
cool
easier to ring them
speak to pete
at spec-r
Old Apr 13, 2005 | 03:21 PM
cossiecrew's Avatar
cossiecrew
pete whats your price then
Old Apr 13, 2005 | 03:30 PM
HYBRiD_T's Avatar
HYBRiD_T
If you change to 2WD fanimold does that mean you have to change your downpipe to a 2WD one?
I've heard the 2WD manifolds are a pain to fit with the engine in, is this just because they are much bigger or because you need some decent shaped tools for the job?.....do they use the same studs as the 4x4?
Old Apr 13, 2005 | 03:40 PM
THE RADMAN's Avatar
THE RADMAN
never seen one without a crack in it , even allegedly mint ones ive looked at have cracks in them when you clean em up
Old Apr 13, 2005 | 03:48 PM
Glenn5's Avatar
Glenn5
dont the spec-r 1s only fit a 2wd head
Old Apr 13, 2005 | 05:20 PM
richm's Avatar
richm
like this one?????
been like it for years, very common, and hasn't caused a problem...
Old Apr 13, 2005 | 05:30 PM
cossiecrew's Avatar
cossiecrew
thats the 1 will have to see what tommorows brings
Old Apr 13, 2005 | 05:35 PM
RichardPON's Avatar
RichardPON
Nope, cos I had one on my 4x4 head.
The idea is you fit a damper when you have the 2wd manifold and 4x4 head combination, as the 4x4 head doesn't have the lug that a 2wd head has to run the std damper.
Why you'd want to run a damper on a 4x4 manifold is beyond me.
Old Apr 13, 2005 | 05:47 PM
richm's Avatar
richm
yep, won't have any effect on the cracking we are talking about here, that's purely temperature-induced
Old Apr 13, 2005 | 09:16 PM
cossiecrew's Avatar
cossiecrew
yeah ive looked at it and see that its a heat issue what pisses me even more is that the 1 that turned up today was the 1 i payed good money for
Old Apr 13, 2005 | 10:20 PM
ian.gordon's Avatar
ian.gordon
mine is cracked too in the same place
Old Apr 13, 2005 | 10:27 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Phewwww, I've been told not so long ago that a t-damper was unnecessary on a 4x4 and started to have second thoughts, that clears things up. Thanks Rich/Nath
Old Apr 14, 2005 | 06:51 AM
Beach's Avatar
Beach
Unlucky mark hope ya get it sorted for sunday mate
Old Apr 14, 2005 | 07:04 AM
whitneyd's Avatar
whitneyd
Does anyone make a damper for the silver top head?
Old Apr 14, 2005 | 07:53 AM
space hoppers's Avatar
space hoppers
i have had the same problem the crack just gets bigger iam going 2wd manifold no uncracked 4wd ones i do no GGR has new ones but dont no wot price from ford they are over 600 quid. getting t4 turbo hanger from spec r as my car is the show car as well as t38 turbo which turbo technics changed over for free as turbo was still new exhaust should fit according to MAD
Old Apr 14, 2005 | 07:56 AM
space hoppers
you are spot on there mate
Old Apr 19, 2005 | 07:32 AM
whitneyd's Avatar
whitneyd
BTT
Old Apr 19, 2005 | 07:49 AM
Azrael's Avatar
Azrael
Originally Posted by richm
like this one?????
Mine is like that any any other 4x4 manifold I've seen. It isn't crack to the outside and it doesn't cause any problems.
Old Apr 19, 2005 | 07:57 AM
richm's Avatar
richm
like this one?????
yeah, exactly, the crack in mine is just on the internal casting web, no sign of it at the outside.
Old Apr 19, 2005 | 08:01 AM
Azrael's Avatar
Azrael
It's easiest to check it with a flash-light
Old Apr 19, 2005 | 08:48 AM
cossiecrew's Avatar
cossiecrew
th3 2 i have are cracked inside and out 1 has been welded on the outside the other hasnt but ive recently got 1 of a guy from here that only has it on the inside so thats whats gonna get used its just abit of a worrie last thing we want is it to come apart and fly off into the new t34
Old Apr 19, 2005 | 09:11 AM
Neil S's Avatar
Neil S
CossieCrew - Was the person who sold you the cracked one called Andy perchance?
My manifold has a crack in it too, has had for at least 2 years, and doesnt cause any chew at all
You can have them welded up as well if needed.
Neil.
Old Jun 4, 2014 | 08:17 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Have anyone used steel exhaust manifold in a Cosworth, do they generally give extra horsepower, and who makes them? Atleast in N/A engines steel manifolds gain quite a few bhp compared to the cast iron scrap.
jessie_rs
62
Aug 6, 2019 09:27 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
DixieTheKid
Sep 14, 2015 09:04 PM
Si B
Sep 12, 2015 06:49 AM
hopper350
Sep 4, 2015 12:53 AM
