Machining zetec block
Old Dec 23, 2018 | 02:14 PM
Lee read's Avatar
Lee read
Rs turbo
Default Machining zetec block
Hi everyone. Does anyone know of a good machine shop around Midlands area so I can get my N/A zetec block bored to 2.1 and get the oil feed and oil return put on. Any help much appreciated.
And merry Christmas to you all
Old Dec 23, 2018 | 05:22 PM
big_wasa's Avatar
big_wasa
Oil feed and return for a turbo ?
feed is already in the block and the return goes in the sump. Again for a fwd blacktop it’s very easy to sort.
Old Dec 23, 2018 | 05:51 PM
Lee read's Avatar
Lee read
Rs turbo
Do you just use she the oil pressure switch goes for feed?
Old Dec 23, 2018 | 06:15 PM
big_wasa's Avatar
big_wasa
You could but I am not a fan of a chunk of brass hanging out of the block. I copy what ford did on the Rs. There is another port behind the low oil switch. It’s the same 1/8npt.
Old Dec 23, 2018 | 06:18 PM
big_wasa's Avatar
big_wasa
This is the genuine ford fitting.
https://www.ebay.co.uk/itm/Genuine-F...kAAOSwKphb99FW
you then need an m10x1.5 banjo bolt
Old Dec 23, 2018 | 06:30 PM
big_wasa's Avatar
big_wasa
Oil return on a Blacktop.
The Rs does have a differant casting for the sump there is an unused bung in the same place that can be drilled and tapped for either a barbed spure or an An fitting.
Lee read's Avatar
Lee read
Rs turbo
Ahh ok so it's a torque screw then. Where have you located you oil return?
Old Dec 23, 2018 | 06:31 PM
Lee read's Avatar
Lee read
Rs turbo
Just got them pictures mate as I sent that. What fittingbdid you use mate?
Old Dec 23, 2018 | 06:50 PM
big_wasa's Avatar
big_wasa
Yes the plug in the oil gallery is a torx.
for the oil return I’ve done several. The one in the photo is a steel jic hydraulic fitting. Ive also done them with ali An10 fittings and a plain barbed spure. The last is the cheapest and was the least hassle.
Old Dec 23, 2018 | 06:55 PM
Lee read's Avatar
Lee read
Rs turbo
What oil feed pipe have you used?
Old Dec 23, 2018 | 07:01 PM
big_wasa's Avatar
big_wasa
Old Dec 23, 2018 | 07:05 PM
big_wasa's Avatar
big_wasa
Old Dec 23, 2018 | 07:07 PM
Lee read's Avatar
Lee read
Rs turbo
Thank you matey. With the oil return how did you finish it of with connecting with the barbed spurs?
Old Dec 23, 2018 | 07:13 PM
big_wasa's Avatar
big_wasa
Push the pipe on and a good quality jubilee clip. It’s not as flash as an An fitting but it didn’t drip or anything.
Old Dec 23, 2018 | 07:23 PM
Lee read's Avatar
Lee read
Rs turbo
Thank you mate for the help. And thank you for the links will be saved
Old Dec 23, 2018 | 07:38 PM
big_wasa's Avatar
big_wasa
No worries, if you find a good machine shop update the post. I may forge mine next year.
Old Dec 23, 2018 | 07:42 PM
Lee read's Avatar
Lee read
Rs turbo
I will buddy. I'm forging mine straight away. I'm a firm believer in do it right 1st time. I'm zvh'ing my escort s2 few things need doing before putting her back together
Cossie Phil
May 19, 2015 06:28 PM
zetecbeast
41
Nov 24, 2012 12:25 PM
darcy
Jan 9, 2012 08:55 PM
Cowboi
53
Jun 23, 2006 03:23 PM
Cowboi
May 7, 2005 11:25 PM
