MT75 2wd gearbox mount shot again
Old Nov 17, 2018 | 08:29 AM
janus's Avatar
janus
Default MT75 2wd gearbox mount shot again
Hey there fellas,
so I have this '91 Sierra 2.0i DOHC 2wd that I built (well, a little bit) for a fun rallye over the Balkan countries in 2016 and now use it as a fun car for drifting in wet/snow conditions and on some closed track wet drifting events for fun - great car for that purpose and I've always been strangely attracted by the Sierra and Scorpios (Gran Mk3) anyways lol.
So, in the front I'm using all poly but the rears are still stock and probably half shot (I know that one of the rear beam mounts has rips). I changed the ripped MT75 gearbox mount in May or sth and now, maybe some few thousand kms later, it's ripped again So that's my question here. Is it usual for them to break that easily under some more heavy usage? Does it have something to do with other mounts (engine mounts looked ok) or bushings that suspend the rear movements or the propshaft intermediate bushing?
Thanks for any inputs & greetz from Austria
Andi
Old Nov 17, 2018 | 08:39 AM
Caddyshack's Avatar
Caddyshack
I think something else could be moving and breaking it, have you got a billet diff hanger on there? Vibratechnics may do a strong gearbox mount.
Old Nov 17, 2018 | 08:41 AM
big_wasa's Avatar
big_wasa
In my kitcar I use heavy duty rover diesel engine mounts all around.
Old Nov 17, 2018 | 09:30 AM
janus's Avatar
janus
Interesting, actually I'm using a billet diff mount with poly insert from anembo, yes, just forgot to mention it! How did ya come up with that lol
You said something else could be moving and then mention the diff hanger? I think that should make things better not move/break it, right?
I just installed that part before the last wet drifting event and at some point that day the gbx mount decided to give up
Old Nov 17, 2018 | 09:42 AM
Caddyshack's Avatar
Caddyshack
I was asking if you had one, if the answer was NO then I was going to say try one to help reduce the movement.
Old Nov 17, 2018 | 10:29 AM
janus's Avatar
janus
Ah I guess I got that wrong then, yes I got one now but still it broke.. maybe has been damaged a little before but I've driven it rarely in those 3 months before I put the diff mount in and still.
So, if I get one of the uprated ones from Vibratech or the like, I guess since there was no Cossie 2wd with the MT75 (or was there?), I'd just get one for a Cossie 4x4?
Old Nov 18, 2018 | 02:52 PM
janus's Avatar
janus
Anyone has some more input on this plz?
Old Nov 19, 2018 | 03:40 PM
R4N SS's Avatar
R4N SS
get a vibratechnics mount for it and that should fix the issue
Old Nov 29, 2018 | 09:54 PM
janus's Avatar
janus
I researched that a little and found that quite some people were complaining about poor fit (gearbox too high and/or having to rework the mount a little for clearance) and poor insulation (although maybe that was the ppl who didn't clearance it). furthermore I could see that vibratech has 3 different sizes in their offering?
another point i've been wondering about - how about the drivetrain damper, coupler assy, intermediate shaft coupler bearing? do these usually go bad a lot and/or is there any useful uprated alternative? as far as i can see, the 4x4 Cossies have the same drivetrain layout with the 2-piece shaft and the coupler assy even has the same P/N 6518778 ?
Old Dec 4, 2018 | 03:16 PM
R4N SS's Avatar
R4N SS
i got a vibratechnics gearbox mount on my 2wd MT75 and it fits fine
Old Dec 5, 2018 | 10:19 PM
janus's Avatar
janus
oh ok thx for the feedback.. which one exactly did you get tho?
Old Dec 6, 2018 | 02:46 PM
R4N SS's Avatar
R4N SS
https://www.amber-performance.co.uk/...php?xProd=7403
Old Dec 6, 2018 | 07:06 PM
janus's Avatar
janus
Thanks for the link R4N! It says Cosworth 2WD and T5 as well as Type9, are you sure?
Old Dec 20, 2018 | 04:00 PM
R4N SS's Avatar
R4N SS
yes that is what i had on my MT75 rear wheel drive
Old Dec 26, 2018 | 05:20 PM
janus's Avatar
janus
Ok, thanks for the input. Didn't see any MT75 cars in your sig, safe for maybe the 24V
Two more questions for me however:
-) how is NVH behavior with that mount, transmission noise became very loud? You specifically linked to the Competition variant.
-) Compatability, i still can't quite believe it since the MT75 is not mentioned in the one you linked, but instead T5 and Type9.. I realize the 4WD cars also had the MT75, but not sure if the mount is maybe completely different here?https://www.amber-performance.co.uk/section.php?xSec=1356&xPage=1] https://www.amber-performance.co.uk/section.php?xSec=1356&xPage=1[/url]
rsstav
Feb 7, 2018 03:17 PM
anglia105e hinson
Dec 5, 2012 06:50 PM
jacko996
Mar 28, 2012 08:03 AM
Tony Ryan
Apr 20, 2006 09:00 PM
Garage19
13
Dec 13, 2005 02:29 PM
