1.8 zvh Service Items
Having just acquired a Series 2 with a 1800cc Zetec boottom end fitted and im a bit unsure as to some service items i may need, so can anyone with knowledge with these engines advise please?
Cam belt i believe will be the original 1.6 RS Turbo?
Cambelt Tensioner from Escort 1.3 CVH?
Will any other belts or parts needed be non RS Turbo ones?
Oil filter unsure of?
Anyone recommend a good engine oil and the capacity with the 1800cc block?
Best spark plugs to use?
Sure theres things ive missed but thanks in advance,Rob.
1.6 belt, 1.3 tensioner - correct
Filter wise, CVH filter is fine. Zetec filter will fit (just) also and obv has slightly better capacity.
Plugs, I'd stick to 071's or NGK BCR8ES - but this is personal preference
peteh
21
Jan 25, 2011 02:01 AM
nickscunny
Jan 9, 2009 05:20 AM
