Ford Granada driveline vibeation
Old Sep 29, 2018 | 03:55 PM
Willem's Avatar
Willem
Default Ford Granada driveline vibeation
Hello guys, this is not really an performance ford but I hope you can point me in the right direction.
My 81 Granada 2.3 4 speed with 76.000km vibrates while driving past 50mph.
I tought it was the rubber in the middle of the propshaft, checked it, had some play so I changed it. Now it's even worse, maybe because I stiffened that part up. U-joints are good. When I took the propshaft away from the car I marked it's position to be sure it would go back as it was.
Where to look?
Old Sep 29, 2018 | 03:58 PM
haz87's Avatar
haz87
Wheel balance been checked? Could be inner CV's also
Old Sep 29, 2018 | 04:11 PM
RichieST's Avatar
RichieST
Have you tried swapping the wheels front to rear to see if the vibration changes?
Old Sep 29, 2018 | 04:45 PM
GVK.'s Avatar
GVK.
Inner CVs used to get dry and require regreasing
Other than that propshaft balance weights may have come off?
wheel balance/ out of shape tyres.
Old Sep 29, 2018 | 05:16 PM
Willem's Avatar
Willem
Weight is still in place, tires are new and balanced. CV joints haven't been checked. Will do. Thanks.
Old Sep 29, 2018 | 05:20 PM
Caddyshack's Avatar
Caddyshack
I would start at the engine mounts and replace everything working back, these cars are so simple that it cannot take a lot to change everything, eventually you will resolve it.
Old Sep 29, 2018 | 06:05 PM
stevieturbo's Avatar
stevieturbo
C**t
And did this just start suddenly, or after work ? Other ?
And it is definitely speed related, not engine rpm etc ?
Swapping wheels or tyres would be a good first step
Old Oct 3, 2018 | 10:03 AM
Willem's Avatar
Willem
Car has been sitting for about 10 years, so I don't know, tires are new but I will swap them for some wheels I have lying around to check if it makes a difderence.
Mashurst
Ford Focus RS Parts for Sale.
May 25, 2018 10:02 PM
studabear
Oct 1, 2013 12:11 PM
24psi boost
Oct 8, 2012 09:55 PM
cool head
Sep 26, 2009 08:47 AM
whitneyd
Sep 30, 2004 04:16 PM
