Ford Granada driveline vibeation - PassionFord - Ford Focus, Escort & RS Forum Discussion
Old 29-09-2018, 04:55 PM
Willem
Default Ford Granada driveline vibeation
Hello guys, this is not really an performance ford but I hope you can point me in the right direction.
My 81 Granada 2.3 4 speed with 76.000km vibrates while driving past 50mph.
I tought it was the rubber in the middle of the propshaft, checked it, had some play so I changed it. Now it's even worse, maybe because I stiffened that part up. U-joints are good. When I took the propshaft away from the car I marked it's position to be sure it would go back as it was.
Where to look?
Willem is offline
Old 29-09-2018, 04:58 PM
haz87
haz87's Avatar
Wheel balance been checked? Could be inner CV's also
haz87 is offline
Old 29-09-2018, 05:11 PM
RichieST
RichieST's Avatar
Have you tried swapping the wheels front to rear to see if the vibration changes?
RichieST is offline
Old 29-09-2018, 05:45 PM
GVK.
GVK.'s Avatar
Inner CVs used to get dry and require regreasing
Other than that propshaft balance weights may have come off?
wheel balance/ out of shape tyres.
GVK. is offline
Old 29-09-2018, 06:16 PM
Willem
Weight is still in place, tires are new and balanced. CV joints haven't been checked. Will do. Thanks.
Willem is offline
Old 29-09-2018, 06:20 PM
Caddyshack
I would start at the engine mounts and replace everything working back, these cars are so simple that it cannot take a lot to change everything, eventually you will resolve it.
Caddyshack is offline
Old 29-09-2018, 07:05 PM
stevieturbo
C**t
stevieturbo's Avatar
And did this just start suddenly, or after work ? Other ?
And it is definitely speed related, not engine rpm etc ?
Swapping wheels or tyres would be a good first step
stevieturbo is offline
Old 03-10-2018, 11:03 AM
Willem
Car has been sitting for about 10 years, so I don't know, tires are new but I will swap them for some wheels I have lying around to check if it makes a difderence.
Willem is offline
Mashurst
Ford Focus RS Parts for Sale.
25-05-2018 11:02 PM
studabear
01-10-2013 01:11 PM
24psi boost
08-10-2012 10:55 PM
cool head
26-09-2009 09:47 AM
whitneyd
30-09-2004 05:16 PM
Quick Reply: Ford Granada driveline vibeation
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
