Euro car parts water pump cossie
Old Sep 15, 2018 | 10:15 AM
Russ6334's Avatar
Russ6334
Default Euro car parts water pump cossie
Hi all
ECP still list a water pump for the cossie using my registration. The photo I think is stock photo but my question is has anyone used one from here?
its £40 yet eBay all cossie ones are circa £140
i suspect ECP perhaps think it’s a 2.0 Sierra not a Sierra cosworth?
anyone know?
thanks
russ
Old Sep 15, 2018 | 01:23 PM
smiley's Avatar
smiley
I wouldn't notoriously crap quality parts whatever the car and on a yb if be using best I could afford to safeguard
Old Sep 15, 2018 | 02:29 PM
costina's Avatar
costina
Live long and prosper!!
Pinto's are alloy construction and just have a alternator to drive.
Cossies are cast iron and stronger due to the twin pulley / ribbed belt design which drives pas,alternator, and AC on some cars.
One of the first pinto's to use the stronger type of water pump was the 2.0i sport sierras. From then on they used the stronger type.
same with 2.0 mk3 Granada's
Old Sep 15, 2018 | 06:57 PM
Russ6334's Avatar
Russ6334
i don’t mind spending the money but eBay ones could be Chinese shite in any case just cause they are £150 no gurrantee where they come from?
Old Sep 15, 2018 | 07:39 PM
costina's Avatar
costina
There is a genuine motorcraft one on there steel bodied one starting at 40 quid.
Search for pinto water pump
Old Sep 15, 2018 | 07:53 PM
Russ6334's Avatar
Russ6334
https://rover.ebay.com/rover/0/0/0?m...2F141172740333
this one?
Old Sep 15, 2018 | 07:57 PM
costina's Avatar
costina
No will see if I can give you a link
Old Sep 15, 2018 | 08:08 PM
costina's Avatar
costina
Old Sep 15, 2018 | 08:09 PM
Russ6334's Avatar
Russ6334
ideal thanks
how come that one is £45 and cossie £145 or is it the typical “cosworth” price tag for the same part!
Old Sep 15, 2018 | 08:13 PM
costina's Avatar
costina
Yes this will be fine for you.
Old Sep 15, 2018 | 08:15 PM
Russ6334's Avatar
Russ6334
ideal want to change it and thermostat when I have cambelt done as it runs hot all the time although fan never comes on but engine is hot 4 hours after using it and runs at Top of the normal mark on guage
Old Sep 15, 2018 | 08:19 PM
costina's Avatar
costina
That also depends what sensor you have in the head for temp gauge as there are so many.
you need to borrow a laser temp gun and see what it's actually doing and when the fans come on etc.
fans come on around 92 degrees and go off 87 degrees while on the move should be in the mid 80's.
Think I am running a 82 degree stat.
Hope that helps.
Old Sep 15, 2018 | 08:22 PM
Russ6334's Avatar
Russ6334
Hope that helps.
havent had chance to go through it properly as the rocker was off for painting and it’s currently 2 feet in the air in my garage being waxoyled and cleaned with a tooth brush!
once I get the rocker on and put the fuel tank back on I’ll go through it properly!
its finding the time with a young child!!
Old Sep 15, 2018 | 08:26 PM
costina's Avatar
costina
I have been there too. Both my daughter's 1st car journey was in a cossie and that was 15 years ago.
Old Sep 15, 2018 | 08:27 PM
Russ6334's Avatar
Russ6334
my daughter loves it too any time she hears a fast car she says cosworth daddy?
I'm sure I read somewhere that the cossie water pump has different fins compared to a normal pinto pump??
Old Sep 15, 2018 | 08:34 PM
costina's Avatar
costina
early ones alloy bodied ones are not one piece later steel bodied ones are one piece fins/ rotor if that make sense.
Again it's just cossie tax
Old Sep 15, 2018 | 08:42 PM
Yeh I know what you Mean matey.
Old Sep 15, 2018 | 08:44 PM
costina's Avatar
costina
Old Sep 15, 2018 | 08:45 PM
Russ6334's Avatar
Russ6334
mine is last of the 4x4 K plate not sure if that makes a difference
Old Sep 15, 2018 | 08:46 PM
costina's Avatar
costina
This one aswell note the cast type impeller.
Also if you wanna cross ref what I am saying look at Lee's resto thread white saff which I done all the work on.
There is a pic of the std pump
Paul
Old Sep 15, 2018 | 08:48 PM
costina's Avatar
costina
Oh fuck yes it does so scrap Everthing I said 4x4 ones are even harder to get hold of and the thermostat used to be very expensive.
sorry I forgot yours was 4x4....
I will try and find one.
Old Sep 15, 2018 | 08:50 PM
costina's Avatar
costina
There are 2 on eBay both 145 to 150 quid
sorry mate.
Old Sep 15, 2018 | 08:52 PM
Russ6334's Avatar
Russ6334
sorry mate.
ill take the thermostat out that’s free! Hahaha
Old Sep 16, 2018 | 08:20 PM
The Youth.'s Avatar
The Youth.
Don't ! you cannot take the thermostat out on a 4x4 set up, it also directs the flow to other parts of the engine so removing it will give you hot spots
Steve
Old Sep 16, 2018 | 08:21 PM
Russ6334's Avatar
Russ6334
Steve
dont worry I was joking!
scottyrs
46
Aug 2, 2011 03:34 PM
lawnsy
Jul 29, 2006 10:27 AM
Dave McB
Jun 8, 2006 04:33 PM
