Euro car parts water pump cossie
Hi all
ECP still list a water pump for the cossie using my registration. The photo I think is stock photo but my question is has anyone used one from here?
its £40 yet eBay all cossie ones are circa £140
i suspect ECP perhaps think it’s a 2.0 Sierra not a Sierra cosworth?
anyone know?
thanks
russ
I wouldn't notoriously crap quality parts whatever the car and on a yb if be using best I could afford to safeguard
Live long and prosper!!
Pinto's are alloy construction and just have a alternator to drive.
Cossies are cast iron and stronger due to the twin pulley / ribbed belt design which drives pas,alternator, and AC on some cars.
One of the first pinto's to use the stronger type of water pump was the 2.0i sport sierras. From then on they used the stronger type.
same with 2.0 mk3 Granada's
you need to borrow a laser temp gun and see what it's actually doing and when the fans come on etc.
fans come on around 92 degrees and go off 87 degrees while on the move should be in the mid 80's.
Think I am running a 82 degree stat.
Hope that helps.
That also depends what sensor you have in the head for temp gauge as there are so many.
Hope that helps.
Hope that helps.
once I get the rocker on and put the fuel tank back on I’ll go through it properly!
its finding the time with a young child!!
