Any Solution for the meelting Coolant Sensor??
Can't say i've ever cooked one. Do you have a standard manifold or custom. If custom is it overly close to that corner of the head? You could use some heat sleeve over the wire and top end of the sender - that should be enough tbh.
the strut brace
Jul 10, 2005 08:20 PM
turbinator
Sep 14, 2004 08:21 AM
