Fitting aftermarket wheels question
Old Aug 26, 2018 | 11:12 PM
qed296's Avatar
qed296
Default Fitting aftermarket wheels question
Hi folks,
found a set of aftermarket wheels and just wondered if I'm going to encounter any issues??
im running standard 4x4 brakes and suspension on my sapphire and have no intention of going bigger/lower
should these be a good fit??
thanks in advance.
The wheels are :
17x8"
ET 40
4x108
Old Aug 26, 2018 | 11:27 PM
costina's Avatar
costina
Live long and prosper!!
8 inch are a little wide.
17x7 Et35 would be ideal with a 215.40.17
Old Aug 27, 2018 | 04:23 AM
Adam-M's Avatar
Adam-M
My only worry would be you might need a spacer to clear your spring base due to being et40, I have 8” et35 on my car but it’s 2wd
Old Aug 27, 2018 | 07:00 AM
Marc sierra's Avatar
Marc sierra
I guess when you're saying it has standard 4x4 brakes it is a Cosworth 4x4?
I have 17x8 ET35 wheels on my 4x4 Sapph with 215/40 tyres, but the front and rear arches have been rolled. I think if you use a 205/40-17 tyre the dimensions are very much the same as the standard 205/50-15, so shouldn't be a problem. But I think 215/40-17 should also not be a problem on standard arches.
Old Aug 27, 2018 | 09:40 PM
cossynut2's Avatar
cossynut2
10 Year Member
Originally Posted by qed296
Hi folks,
thanks in advance.
The wheels are :
17x8"
ET 40
4x108
Have you bought them already? If not I would see if you can do a trial fit which will show you straight away if there will be a fitting problem.99% of wider Saff wheels are et35 but with standard brakes and suspension you may be ok.
Old Aug 28, 2018 | 07:17 AM
qed296's Avatar
qed296
No just looking at options.....Would adding a 5mm spacer reduce them to et35??
Old Aug 28, 2018 | 07:26 AM
qed296's Avatar
qed296
Old Aug 28, 2018 | 04:24 PM
qed296's Avatar
qed296
Seems the UK supply of these is in fact et42 so even less chance of fitting.
hopefully I should have some bbs e50 replica wheels soon so these are not even in contention now.
Old Aug 28, 2018 | 09:26 PM
cossynut2's Avatar
cossynut2
10 Year Member
Stick with wheels which are the right size for your car so you don't have any worries.
dannyblackpool
Feb 13, 2010 08:23 PM
DHMC
Oct 18, 2009 07:03 PM
EssexMikeSi
Apr 7, 2008 06:48 AM
mikee_rs
Oct 28, 2007 01:27 AM
Roosie
Jan 10, 2007 08:19 AM
