battery light glowing
Old Jul 5, 2018 | 03:17 AM
lime's Avatar
lime
Default battery light glowing
hi guys my sapphires battery light glows while driving the B+ wire is good the wire from the clocks is ok , when the car is started the charge light goes out and all is well until the car warms up or i turn on the lights or indicate the lights starts to glow , the alternator is new from grahme goode I'm at a lost as what to do to find the issue
Old Jul 5, 2018 | 05:44 AM
haz87's Avatar
haz87
Earths nice and clean inc. the alternator mounting points?
Old Jul 5, 2018 | 07:36 AM
cossynut2's Avatar
cossynut2
10 Year Member
Although the alternator is brand new have you checked it to see if it is charging properly? Is the battery in good condition? The symptoms sound like when there is an extra draw on current the alternator is not charging as it should be.
I had the same sort of thing a while back on my Saff and it was a faulty alternator. When you put the new alternator on did you by accident trap any wires or put any of them back on in different positions to how they were originally? Double check everything as it's sometimes a very simple thing that could be causing the problem. Hope you sort it out ok.
Old Jul 5, 2018 | 08:03 AM
Caddyshack's Avatar
Caddyshack
Can you run a meter on the Alternator to check its output or send it away for testing. I would do as the posts above say and check all wires and maybe run some test earths to each part.
Old Jul 5, 2018 | 11:36 AM
iansoutham's Avatar
iansoutham
OCD Victim
How much does it glow?
I have seen the foam between the indicator lamps in the instrument cluster disintegrate which allows some light from the backlighting and lamp next to the alternator through so it can make it look like it is on when it is not. Worth checking that as well if the charging checks shown nothing.
Old Jul 5, 2018 | 12:37 PM
lime's Avatar
lime
will check the earths , the alternator was checked was putting out 13.9v, not sure how to check battery condition but if i charge it externally it does not drop voltage and the battery light is an external one and it glows so slight that i have to put my hand around it to see it some times
Old Jul 5, 2018 | 12:47 PM
haz87's Avatar
haz87
Do you have the original wiring/diode installed?
Old Jul 5, 2018 | 12:48 PM
lime's Avatar
lime
no i don't
Old Jul 6, 2018 | 05:49 AM
lime's Avatar
lime
problem solved it was the grounding cable , changed all of it including the alternator wire now i have 13.9v
Old Jul 6, 2018 | 07:56 AM
cossynut2's Avatar
cossynut2
10 Year Member
Glad you got it sorted and it was a fairly simple fix.
Old Jul 6, 2018 | 08:03 AM
haz87's Avatar
haz87
Easy/cheap fix
Chopshop85
Mar 22, 2015 05:20 PM
retroadder
Dec 10, 2013 01:05 PM
skypeller
Nov 19, 2009 07:14 AM
andre_k
Mar 6, 2007 09:54 PM
