XR3I TO RS TURBO CONVERSION QUESTION
Old Apr 12, 2005 | 06:39 PM
bonio's Avatar
bonio
Default XR3I TO RS TURBO CONVERSION QUESTION
[/b]IVE GOT AN XR3I CABBIE AND IM SICK OF GETTING LEFT AT THE LIGHTS BY OLD WOMEN ON SHOPPIN SCOOTERS SO I WANNA DROP IN A TURBO BUT WHICH IS THE BEST OPTION ESCORT OR FIESTA TURBO AND WILL I NEED TO USE A DIFFERENT WIRING LOOM AND ECU ?
P.S DOES ANYONE KNOW THE BEST WAY TO SQUEEZE MORE POWER OUTTA THE ENGINE IVE ALREADY GOT FOR TIME BIENG ?
Old Apr 12, 2005 | 06:54 PM
Rs1's Avatar
Rs1
Exhaust,filter and plugs is a good start on any engine but you aint gonna get much back from the 3i lump. Personally i'd go for the erst lump and management. Its quite easy to find, easy to fit and wiring is pretty much straight forward aslong as you get the full engine harness. You'll need both ecus aswell to run the engine,radiator,intercooler and metering head.
Old Apr 12, 2005 | 07:01 PM
bonio's Avatar
bonio
SOMEONE TOLD ME THE FIESTA RST DROPS STRAIGHT INTO A 3I AND ITS NOT AS MUCH FUKIN ABOUT DONT SUPPOSE YOU KNOW WHAT SIZE ENGINES THEY MADE FOR THE FESTA TURBO OR WHEN THEY STOP MAKING THEM DO YA
Old Apr 12, 2005 | 07:09 PM
Rs1's Avatar
Rs1
All rst's are 1.6. I think the last frst was on a j plate. Both escort and fiesta rst use the same engine so one isnt any more of a straight fit than the other. The engine fitment wont be the problem, the wiring of the frst may be as it efi. It has a few extra sensors and a different inlet manifold. Apart from that they should be identical.
Come to think of it the frst may have a smaller turbo too.
Old Apr 12, 2005 | 09:37 PM
Mr.h.'s Avatar
Mr.h.
frst has a t2 ,erst has t3
Old Apr 13, 2005 | 03:20 AM
xr2itrojan's Avatar
xr2itrojan
id go for the frst engine because you get the chatter sound and just bolt a t3 turbo off the escort onto it. for the engine and all the bits you would need it will cost you around £700 im not sure what you would do about fitting the rad and i/cooler if its a mk5 though but have a search on here and www.fiestaturbo.com some1 will have done it b4.
Old Apr 13, 2005 | 08:59 AM
davidnormanuk's Avatar
davidnormanuk
What year's your cabbie on? Is it the one with EFi or MFi?
Did mine not so long ago. Really easy to do. Just takes a nit of time.
Matt Baxter
Sep 16, 2015 08:30 PM
Dahl88
Aug 22, 2015 08:16 PM
A.t.p
Aug 15, 2015 11:37 AM
marky_g
Aug 15, 2015 10:43 AM
stevierob
Aug 11, 2015 09:08 PM
