Cosworth driveshaft gaitors
Old May 20, 2018 | 02:42 PM
timsrs's Avatar
timsrs
Default Cosworth driveshaft gaitors
Need to replace mine
Ones I’ve seen on eBay seem to have s metal flange on them
Has anyone fitted these or are they correct
Car is a 2WD sapphire
Thanks
Link to gaitors
https://m.ebay.co.uk/itm/FORD-SIERRA...-/140871542320
Old May 20, 2018 | 03:31 PM
Mark V8's Avatar
Mark V8
I think that's where I bought mine from, they fit the CV joints OK but the standard load spreading washers do not clear the new metal bit.
You will either have to grind or file some clearance on the washers or leave them off.
Old May 20, 2018 | 04:00 PM
3drRich's Avatar
3drRich
I've bought a few sets off eBay in the past and not been great, I would get them from graham Goode personally.
Old May 20, 2018 | 04:50 PM
timsrs's Avatar
timsrs
Thanks seen them from Graham Goode
Also the actual CV joints do they come apart so I can get fresh grease in them
The old grease seems to have seen better days
Old May 20, 2018 | 08:50 PM
Mark V8's Avatar
Mark V8
They come apart easy enough
Putting them back together is more of a fiddle
I bought a new set from here
http://www.prolinx.biz/pages/Product...08mm-CV-Joint/
Then stripped them to send the outer parts for plating.
If you're going to take them apart, get a dremmel and mark the inner cage relative to the outer part and keep the ball bearings with the matching joints.
Old May 21, 2018 | 06:00 PM
timsrs's Avatar
timsrs
Thanks stripped them
Showing some small wear marks
Don’t seem to have any play in them though
What symptoms if they have excessive wear
Here’s s pic
Attached Thumbnails Cosworth driveshaft gaitors-5acc0cb4-018d-4466-8291-f02f17bc17f3.jpeg   Cosworth driveshaft gaitors-2f785760-99b1-4739-a353-595f6511411a.jpeg
Old May 22, 2018 | 10:34 AM
timsrs's Avatar
timsrs
Are the Graham Goode ones any good to cope with 450 bhp
Old May 22, 2018 | 11:11 AM
tosh's Avatar
tosh
Here’s s pic
I’m not an expert but they look ok from the photos and have seen much worse I would re-grease them, also google CV joint clocking which tells you about the
positioning of each CV joint on each shaft.
Hopefully others will confirm this.
james kiely
Jul 4, 2013 06:24 PM
khanny1
Dec 4, 2011 03:32 PM
lukemakepeace
Oct 9, 2007 05:48 PM
