cv joint gaitors
Old Oct 9, 2007 | 12:31 PM
lukemakepeace's Avatar
lukemakepeace
Default cv joint gaitors
on my bros 106 (gay peugeot) i need to change both outer cv gaitors for the MOT. can someone explain what i need to do fully.
Old Oct 9, 2007 | 05:48 PM
jawanne's Avatar
jawanne
hi take the wheel off then the crown nut that is in the middle of the disc remove the bottom arm and take the shaft out of the hub and push the gaitor of the cv joint and where the shaft goes in the cv joint there is a metal clip .you will needs to use serclip pliers to sqeeze the clip in and at the time when you are sqeezeingf the clip in pull the shaft out of the cv joint
SMILER258
Sep 28, 2015 09:04 AM
martynhomer01
14
Sep 23, 2015 12:23 AM
Mark V8
Sep 13, 2015 09:34 AM
rsturbo27
Sep 5, 2015 05:08 PM
