Cosworth driveshaft gaitors
Need to replace mine
Ones I’ve seen on eBay seem to have s metal flange on them
Has anyone fitted these or are they correct
Car is a 2WD sapphire
Thanks
Link to gaitors
https://m.ebay.co.uk/itm/FORD-SIERRA...-/140871542320
Thanks
Link to gaitors
I've bought a few sets off eBay in the past and not been great, I would get them from graham Goode personally.
Thanks seen them from Graham Goode
Also the actual CV joints do they come apart so I can get fresh grease in them
The old grease seems to have seen better days
They come apart easy enough
Putting them back together is more of a fiddle
I bought a new set from here
http://www.prolinx.biz/pages/Product...08mm-CV-Joint/
Then stripped them to send the outer parts for plating.
If you're going to take them apart, get a dremmel and mark the inner cage relative to the outer part and keep the ball bearings with the matching joints.
Thanks stripped them
Showing some small wear marks
Don’t seem to have any play in them though
What symptoms if they have excessive wear
Here’s s pic
Here’s s pic
positioning of each CV joint on each shaft.
Hopefully others will confirm this.
james kiely
04-07-2013 06:24 PM
