Turbo Heat Shield Repair ??
Old May 11, 2018 | 08:24 PM
qed296's Avatar
qed296
Default Turbo Heat Shield Repair ??
Evening all,
My turbo heat shield isn't in to bad a condition but does have a flap of material that needs fixing.
Any ideas on how to fix it and spruce it up to make it look clean and tidy.
pictures as always of your work appreciated.
Old May 11, 2018 | 09:33 PM
costina's Avatar
costina
Live long and prosper!!
Fibre glass resin then give it all a good sanding.
paint with a high heat temp satin black spray.
Old May 11, 2018 | 09:51 PM
qed296's Avatar
qed296
Oh, as simple as that.....
I was just concerned about temp and the effect on the repair.
Old May 12, 2018 | 07:06 AM
cossynut2's Avatar
cossynut2
10 Year Member
Have you tried the various Cosworth breakers for a good used one?
Old May 12, 2018 | 07:10 AM
qed296's Avatar
qed296
Not really looking to get another, this is really good compared to some.
The mounting holes are all ok, not opened up or fraying it's just this small area and a little discoloured.
It's worth fixing.
Old May 12, 2018 | 10:15 AM
cossynut2's Avatar
cossynut2
10 Year Member
It's worth fixing.
Fair enough, have a go at doing it yourself then, seems like its not to hard to repair.
Old May 12, 2018 | 10:58 AM
Caddyshack's Avatar
Caddyshack
If you do it with fibre glass as above have said and if worried about the heat still just let me know and I will post you enough stick on heat shield to line the inside with, I have a lot leftover.
Old May 12, 2018 | 11:41 AM
qed296's Avatar
qed296
Thanks caddy, I'll take you up on that����
Matt Baxter
Mar 26, 2012 06:12 PM
FestaRST
Sep 29, 2008 07:26 PM
Cola
11
Aug 2, 2006 09:26 AM
scooby8272
Dec 6, 2004 10:21 PM
arch
Ford Escort RS Cosworth
14
Oct 6, 2004 11:02 AM
