Rear axle bearing housing torque plus seal deep
Old May 5, 2018 | 04:50 PM
florent78's Avatar
florent78
Default Rear axle bearing housing torque plus seal deep
hi
i m mouting back on the rear arm the bearing housing with the 4 bolts
i m quite confuse regarding the datas i find the torque setting is 19 to 25 nm
but regarding the bolt : m10 10.9
this torque value is not standard
i m wrong ?
or yes it s 19-25 nm for the 4 m10 bolts
thanks for your help
Old May 5, 2018 | 05:18 PM
Mark V8's Avatar
Mark V8
From looking at the manual it depends on what bolts you have...
Old May 5, 2018 | 07:25 PM
florent78's Avatar
florent78
Perfect
thanks a lot
Old May 6, 2018 | 07:47 AM
florent78's Avatar
florent78
Default Up
I m using a new bearing housing from anembo
so everything comes fitted bearing seals etc
when i mount back the hub and tighten
it was impossible to move it after
it seems the seals on the anembo kit are not in the correct position
not enough inside so the outside is crompressed too much
looking the doc it seems there is a special tool
14-019 to insert and get the correct deep for the seal
i do not have this tool
i should put the seal 1mm? More inside the bearing housing ??
Old May 6, 2018 | 10:28 AM
Mark V8's Avatar
Mark V8
I had to tap the seal on mine, seemed OK after.
Prior to that I had to send them back for re-machining as the bearings were a bit too tight.
Sent them my old hub carriers to double check the size of the little ledge between the two bearings.
They were very helpful and sorted it quickly.
Old May 6, 2018 | 11:05 AM
florent78's Avatar
florent78
I think i will do the same
send back to anembo
i agree greig is lovely and always locking to find a solution
bearing seems ok
but with the seals too tight you cannot turn the hub by hand so ... problem
i will tell you
thanks
cozi500
Dec 22, 2009 08:35 PM
herbie
Nov 28, 2009 03:55 PM
dunketh
Jul 3, 2008 10:12 AM
EsCosRacer
Ford Escort RS Cosworth
Jun 18, 2006 10:39 AM
morto
Feb 17, 2005 10:20 PM
