Rear Bearing sutck on Axle.
Old 02-07-2008 | 01:16 PM
dunketh's Avatar
dunketh
Chief Iron Oxide Farmer.
Default Rear Bearing sutck on Axle.
Help!
OK, so it aint an RST, but the rear bearings are the same so don't flame me!
To cut the story short I now have the center of the 'outbound' bearing jammed on my stub axle.
The rollers and cage fell out in a tangled mess when I removed the hub leaving the center jammed fast on the spindle.
No amount of whacking, swearing (incl the C word!), will shift it.
It appears to have pretty much welded itself to the axle both in the center and at the edge of the conical piece that it buts up against.
Any ideas?
I cant be the first poor sod to have this happen... I certainly cant be bothered with replacing the stub axle though I can see its doable without too much hassle.
Old 02-07-2008 | 01:33 PM
DazC's Avatar
DazC
Get a plumbers blow torch and a thin but sharp chisel.
Heat the bearing race with the blow torch for as long as you can all the way around the race itself to make it expand away from the stub axle. While its still hot, use the chisel to act as a wedge between the part of the stub axle that the race butts up agains and the race itself and hit the chisel with a hammer.
Old 02-07-2008 | 03:33 PM
dunketh's Avatar
dunketh
Cheers.
I was thinking of applying some heat, provided I can scrounge-up a blowtorch.
Hopefully it'll shatter into a million bits, teach the *** thing a lesson.
Old 02-07-2008 | 04:38 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
ig u 100% careful u can grind it off!!but i would heat it first!
Old 02-07-2008 | 05:08 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
chiesel it off, heat usially helps to ease it out, but a good few whacks with a sharp chiesel to get it rotating a little will work wonders.
Old 02-07-2008 | 06:01 PM
DazC's Avatar
DazC
Originally Posted by dunketh
Cheers.
Just go and buy one from B&Q!! They're not that expensive!
Old 03-07-2008 | 09:12 AM
dunketh's Avatar
dunketh
Nothing would touch it.
A mate used a large blow torch (not a little plumbers one) and heated it to buggery until the whole stub was roasting.
We were hitting it with various cold chisels from behind, having removed the backplate.
Absolutely nothing. All we did was turn it blue and put a tiny nick in it. The chisel was hard and sharp, sparks were coming off it but nothing doing.
I ended up removing the stub axle and sending it up to another mates house where he ground one side of the bearing flat and tapped it off.
Funny as I didnt see any mention of beating 7 shades out of a bearing in my Haynes BOL. I must have missed that step...
Old 03-07-2008 | 10:12 AM
DazC's Avatar
DazC
At least you got of though!!
Grinding weakens it so it doesn't grip as much. Usually a last resort though!!
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
155lee
27-10-2015 04:55 AM
cossirob
03-09-2015 09:17 PM
Quick Reply: Rear Bearing sutck on Axle.
