Cossie head core plug
Old Apr 29, 2018 | 07:12 AM
The Crocodile Hunter's Avatar
Default Cossie head core plug
Traced a water leak on my saph back to one of the core plugs on the exhaust side of the head so a new plug is needed.
Anyone got any tips on how to remove these? Looks like it would be easier with the manifold removed, however I said to myself last time that I would never do that job again with the head on/engine in the car!
Hopefully I can just remove the downpipe for access, here is a pic
Old Apr 29, 2018 | 08:47 AM
costina's Avatar
costina
Live long and prosper!!
Drill hole in centre and prise out. Use a block of wood to lever against.
Old Apr 29, 2018 | 09:21 AM
If I can get a drill in there, not looking forward to this job
Old Apr 29, 2018 | 08:42 PM
stevieturbo's Avatar
stevieturbo
C**t
Sometimes you just have to take things apart....both to get parts out and ensure any new one you fit is in correctly.
Old Apr 30, 2018 | 02:54 PM
I suppose I'm in no rush to do it so can take my time.
Will these plugs spin if you hit them with a hammer and screwdriver? Or are they against a lip in the head?
Old Apr 30, 2018 | 03:02 PM
St3V3_C's Avatar
St3V3_C
Not in the same place, but last time I did one, I knocked a screwdriver through it I'm sure...
Old Apr 30, 2018 | 06:14 PM
stevieturbo
C**t
It might...you might just knock a hole in it, or it could end up inside the waterways in the head which you then still need to get it back out.
Ideally though try and pull it out and as it's already corroded it should be easier to get something in to try that.
Oil seal pullers are pretty handy tools
But they can be awkward both to remove and get back in as they are just an interference fit. Hence the better access you have the more chance you have of not making a mess.
Old Apr 30, 2018 | 07:32 PM
turblower's Avatar
turblower
Im doing the same thing this week.iv removed the turbo an exhaust manifold for easier access.i used a tool which is like a small sliding hammer which is like a screw on the end..I made a little hole for the screw to go into,screwed it in then gave it a few slides an it came out.i did try to hit it with a hammer an chisel but is a bit dodgy doing that way by hitting the head..
Old Apr 30, 2018 | 07:54 PM
Think I've decided I'm going to take the manifold off, even though it's a complete pain in the arse.
I know the slide hammer tools you mean, I might invest in one. Last think you want to do is damage the head
Old May 1, 2018 | 06:52 AM
cossynut2's Avatar
cossynut2
10 Year Member
For me the days of trying to do things without the right tools for the job or leaving parts in place which get in the way are long gone. It may seem a lot of extra work but once you have a clear working space the job is so much easier to do and eliminates the risk of damaging something else.
BRAMMER
Sep 19, 2011 11:21 AM
Mids_s2
Aug 17, 2011 02:23 PM
rickbartlett
Jan 24, 2011 06:03 PM
pete mcrash
15
Oct 29, 2009 05:53 PM
Thrush
Computers, Consoles and I.T.
20
Jan 7, 2008 05:44 PM
