Amal valve relocation
Old Apr 27, 2018 | 09:11 PM
qed296's Avatar
qed296
Default Amal valve relocation
I'm tidying up the engine bay and moving the amal valve, I have a new plug but what gauge wire do I need to extend
the lead.
I can see the lead but I've no idea of amps etc etc.
thanks folks.
Old Apr 29, 2018 | 08:03 PM
scrotenz's Avatar
scrotenz
Since no one has advised the correct gauge. A previous owner on my car used speaker wire to extend it. I also dont know what is the correct gauge so I tided it up with https://www.jaycar.co.nz/heavy-duty-...black/p/WH3037 and it seems fine.
Old May 1, 2018 | 06:09 PM
qed296's Avatar
qed296
Moved the valve today to the back of the airbox, looks a lot better hidden out the way. Just need to extend the lead to it.
Old May 1, 2018 | 09:51 PM
jimhc's Avatar
jimhc
big jc
Very tidy. What route did you take to get to the airbox without seeing the wires?.
Old May 2, 2018 | 05:10 AM
qed296's Avatar
qed296
That's the next job, 2 options....along the slam panel to the o/s headlight then up the inner wing with the original loom or neatly route it along side the throttle cable in a cable tidy/wrap.
Old May 2, 2018 | 12:40 PM
jimhc's Avatar
jimhc
big jc
I think under the slam pannel would be the way I'd run it?
Old May 2, 2018 | 12:47 PM
qed296's Avatar
qed296
Just picked up some wire and split sleeve.
14 strand 0.30 gauge wire seems a good fit.
I'll do both to see which is best..
Old May 2, 2018 | 12:52 PM
jimhc's Avatar
jimhc
big jc
Thinking of doing the same as you. Bloody eyesore
Old May 2, 2018 | 01:06 PM
qed296's Avatar
qed296
And I'm forever catching my arm on the plate it sat on.
Old May 2, 2018 | 06:31 PM
qed296's Avatar
qed296
All sorted. Went along the slam panel.
Old May 3, 2018 | 09:35 AM
jimhc's Avatar
jimhc
big jc
The guy that owned the car before screwed it to a small piece of aluminium and it looks horrific.
lamar69er
Ford Escort RS Cosworth
Jul 24, 2006 06:59 AM
rs-nut-john
Mar 8, 2005 10:29 PM
Azrael
Dec 20, 2004 11:08 PM
Dec 17, 2003 11:06 PM
