Amal valve + bleed valve?
I'm looking forward to witching to boost control enabled chip so I'm wondering about the possibilities. I have now my amal valve totally disconnected - multiplug and boost feeds. Now when I put new chip in I schould just connect the boost feeds from compressor housig to the actuator throught the amal valve and conect the multiplug. Can I have my bleed valve still put on one of the lines or is it stupid/unneccesary so on? How do I know wich line goes where on the valve?
Is there any other things I have to do to have working boost control? It will be small turbo Escos chip by Stu@MSD
Originally Posted by Stu @ M Developments
It works actuator to compressir with the valve connected into this line via a "T" piece.
The problem is that the T piece is actually calibrated and you need to get it the correct way around.
Bleed valve wont be necessary.
Shit :-/ is it possible to get the T-piece from traders or is it some standard automotive part? I thought there was two outlets on the valve but maybe I was wrong it's well hidden behind intecooler.
Testing the future
no need to fit air injectors, the escos 'amal' (not made by the same company that makes the boost control valve for sierras in a place called amal, but it's called a lEktron valve) valve is well up to the job when used with the t-piece (ford part number 6909194 for the t-piece, and 6737450 for the straight pipe)
I understand the t-piece but what is the straight pipe for? I just looked at Microcat and have no idea where the ther pipe from the valve would go.
