Coolant system refill
Old Apr 25, 2018 | 09:03 PM
qed296's Avatar
qed296
Default Coolant system refill
Finally got around to draining the coolant out so I can replace all the blue silicone hoses with the o/e matt items.
Drained down no issue's, flushed out till running clear.
New pink/red oat antifreeze at the ready......
What's best practice for refilling.....
fill up till I have fluid staying in the header tank,
start it up,
keep topping up till a good level in the H/T,
do I put the cap on at this point till the fans kick in??
Or leave it off and wait for it to start bubbling??
do the heaters want to be on at all during this??
check all hoses are hot, top up H/T ??
any bleed screws in the system to vent air??
Probably basic stuff to most of you but I want to get it rite as best I can.
cheers
(4x4 jreg sapphire)
Old Apr 25, 2018 | 09:15 PM
tosh's Avatar
tosh
Have always just filled mine up to max then let it run to circulate for a bit with cap off and then top up as necessary.
Old Apr 25, 2018 | 09:36 PM
costina's Avatar
costina
Live long and prosper!!
Fill system from empty by removing small pipe on side of thermo housing once coolant runs from there refit and fill. Run with cap off and check.
Old Apr 27, 2018 | 07:04 AM
4x4kiwi's Avatar
4x4kiwi
4x4 does have a bleed screw on top of the thermostat housing.
David
Old Apr 30, 2018 | 08:47 PM
qed296's Avatar
qed296
All done, checked all new hoses and clips, filled up....Started up....topped up till a good level....left to run with no cap on....fans kicked in...job done.
Old May 1, 2018 | 08:50 PM
martysmartie's Avatar
martysmartie
I personally just fill up until at the correct level then just top up for the small loss after it's been run.
Martin
fordsteve77
Escort MK 5 / MK 6
Jan 22, 2016 07:50 AM
Lee_R21Turbo
Apr 4, 2011 12:06 PM
gus
May 4, 2006 07:47 PM
zaki
May 11, 2005 10:25 PM
