Fusion TDCI Problems
Old Apr 11, 2018 | 12:00 PM
colins2's Avatar
colins2
Default Fusion TDCI Problems
I have a fusion that does not start it started off as an intermittent fault but has now died completely 0 fuel pressure at the rail on the diag machine, another garage has fitted a pressure sensor in it made no difference obviously this was when the fault was intermittent, is there any of you guys has access to a wiring diagram ECU pin outs, going to check the fuel pump pressure reg feed tonight.
little6872
Nov 3, 2017 10:59 AM
Fil
12
Mar 28, 2013 07:41 AM
Fedup14
Mar 10, 2010 10:19 PM
Demondave
Jun 17, 2004 12:43 PM
Lee @ Fusion
22
May 14, 2004 07:36 PM
