Fusion TDCI Problems
I have a fusion that does not start it started off as an intermittent fault but has now died completely 0 fuel pressure at the rail on the diag machine, another garage has fitted a pressure sensor in it made no difference obviously this was when the fault was intermittent, is there any of you guys has access to a wiring diagram ECU pin outs, going to check the fuel pump pressure reg feed tonight.
Lee @ Fusion
22
14-05-2004 07:36 PM
