Yb dies when warm
Old Apr 8, 2018 | 06:35 PM
cosmatt's Avatar
cosmatt
Default Yb dies when warm
Hi all,i have a 2wd cosworth engine in an old escort and its developed a problem. After half an hour or so driving it,it starts to misfire to the point that i have to pull over as it cuts all 4 cylinders and pops and bangs as soon as i try to rev it. Turn it off and after 10 mins its fine. Ive changed coolant temp sensor and checked gaps on crank and phase. Its on l6 ecu running stg 3. I tested pump voltage today and its at 11.3v. But when i rev it and its missing,it bangs and flames out exhaust. Anyone any idea?
Old Apr 8, 2018 | 06:54 PM
Caddyshack's Avatar
Caddyshack
Check the earths, then check all of the loom
Old Apr 8, 2018 | 06:59 PM
cosmatt's Avatar
cosmatt
What do i need to be looking for with the loom? I cant see any obvious breaks. I did probably 25 miles in it today before it started. Turned it off,waited 10 mins then drove home where it started again
Old Apr 8, 2018 | 07:32 PM
james kiely's Avatar
james kiely
Definitely not enough voltage at the pump.you want close to battery voltage of 13 + volts.
Check your alternator to battery cable as well as your pump wiring for condition.definatley losing power somewhere
james kiely
Old Apr 8, 2018 | 07:47 PM
cosmatt's Avatar
cosmatt
Battery is in boot with pump set up so going to wire a feed from battery tomoz using the old pump feed as a trigger on relay. Should be over 13v then.
Old Apr 9, 2018 | 04:41 PM
R4N SS's Avatar
R4N SS
fit a new fuel pump wiring loom
Old Apr 9, 2018 | 04:44 PM
Caddyshack's Avatar
Caddyshack
Agree with the fuel pump re-wire.
Old Apr 9, 2018 | 06:51 PM
I had a fault with my cossie. I could do a steady 50/60 mph but as soon as I go into town traffic my cossie would start misfiring.
I replaced the water temp sensor and it cured my fault.
Old Apr 9, 2018 | 08:52 PM
cosmatt's Avatar
cosmatt
That was my first thought so i changed it. Thought it was cured until it started again on sunday. Guess the new sensor could be faulty. Would charge air sensor affect it like this as not changed this
Old Apr 10, 2018 | 06:27 PM
grcossie's Avatar
grcossie
I had the same on my Sapphire, it was the water temp sensor, i read out fault code on it. On L6 With stg1
Old Apr 19, 2018 | 07:55 PM
cosmatt's Avatar
cosmatt
Quick update,changed cts,brown air temp,dizzy cap and rotor,cleaned plugs on loom and rewired pump.so getting 13.5v. Been out today (hot day) upto temp to point of fans coming on and all seems good
Old Apr 19, 2018 | 08:17 PM
Caddyshack's Avatar
Caddyshack
Yey, they are old cars and need a bit of care
Old Apr 19, 2018 | 09:42 PM
gcfcos's Avatar
gcfcos
Result mate, long may it continue
Old Apr 23, 2018 | 06:28 PM
I hope it's sorted matey.
mgtkr1
Jan 12, 2012 11:24 AM
cozi500
11
Jun 11, 2011 04:54 PM
RC4
Mar 12, 2005 04:31 PM
Jimmermac
Nov 16, 2004 01:13 PM
RS500/364
Oct 2, 2003 07:30 PM
