3bar map or 4bar map advice please
Old Apr 6, 2018 | 08:21 PM
COLEYST200's Avatar
COLEYST200
Default 3bar map or 4bar map advice please
hi lads iv just blown my 3rd 3bar map censer tonight not happy . Any way brands hatch on ebay are doing a 4bar map all the same as the 3bar dose any one no if I could just plug and play or would I have to get my car remapped ??
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F 122170940832
Old Apr 6, 2018 | 09:07 PM
Ridgey's Avatar
Ridgey
You will need ecu programme adjusting, as the output 0-5v or what ever it is of the MAP sensor will now be for 0-4 bar and not 0-3 bar.
So the scaling is different.
Old Apr 6, 2018 | 09:59 PM
COLEYST200's Avatar
COLEYST200
Thanks very much for the info very good of you
Old Apr 7, 2018 | 02:49 PM
markk's Avatar
markk
Needs recalibrating.
I have a 4 bar on mine with the integral air temp sensor. I run a peak of around 3.5 bar.
Old Apr 7, 2018 | 03:36 PM
Caddyshack's Avatar
Caddyshack
Please excuse a silly question but when our turbos only run at say 2.2 bar why do we need 4 bar and where on the car do you see 3.5 bar?
Any why would Ian blow a 3 bar?
Old Apr 7, 2018 | 03:49 PM
markk's Avatar
markk
Pressure is absolute not gauge pressure.
The ecu needs to have the lowest pressure scaled against the voltage range.
E.g. 0.5v - 4.5v sensor range to the lowest pressure 30kpa or 0.30bar.
Remember your engine will run at vacuum. Vacuum is just low pressure. Lower than atmospheric.
Either over pressure on the sensor range (running more than 2bar gauge pressure) or shit sensors.
Old Apr 7, 2018 | 03:59 PM
Caddyshack's Avatar
Caddyshack
Got it, thanks
Old Apr 7, 2018 | 04:18 PM
Adam-M's Avatar
Adam-M
3 bar map sensor covers you for 1 bar vacuum pressure and 2 bar positive
Old Apr 7, 2018 | 04:20 PM
Adam-M's Avatar
Adam-M
Sensor could be failing due to the way they are mounted I.e too much heat or vibration
Old Apr 7, 2018 | 04:48 PM
costina's Avatar
costina
Live long and prosper!!
I would buy a 3bar from msd as it's the ones they now use.
James has said there are not enough map points in the table on a Weber ecu to make the engine run smooth with a 4 and 5 bar map.
Old Apr 8, 2018 | 08:55 AM
stevieturbo's Avatar
stevieturbo
C**t
This would be a rather more important question.
Although I suspect China might have the answer.
Old Apr 8, 2018 | 09:33 AM
turbotrev's Avatar
turbotrev
I run a 5 bar sensor on mine (still level 8 management), was then live mapped on the road
Cheers Paul
turbotrev's Avatar
turbotrev
Heard them bhp sensors are rubbish too so I’d get a decent genuine one buddy
Cheers Paul
Old Apr 8, 2018 | 09:36 AM
stevieturbo
C**t
There should be little reason almsot any sensor could not be used, but yes the ecu will need re-tuned to suit the voltage/pressure scalings of that sensor.
Problem is most cheap sensors these days are Chinese.
Chip
139
Aug 26, 2012 08:39 AM
Mark_1
Apr 28, 2011 09:56 PM
biglee
60
Dec 20, 2009 06:05 PM
cossiemen
Nov 21, 2007 11:34 PM
TIFF
Sep 27, 2004 03:51 PM
