Which axle to run 400 hp cossie in a mk2
Old Apr 4, 2018 | 09:29 PM
smiley's Avatar
smiley
Default Which axle to run 400 hp cossie in a mk2
As title my mates building a mk2 rs2000 and will be having my engine out of the saph and wants to know what's best suited
Thanks in advance
Old Apr 4, 2018 | 09:43 PM
stevieturbo's Avatar
stevieturbo
C**t
Usually a few MK2 guys over on Turbosports too might be able to answer
Old Apr 5, 2018 | 05:45 AM
smiley's Avatar
smiley
Cheers mate
Old Apr 5, 2018 | 06:20 AM
timsrs's Avatar
timsrs
I’m running a baby atlas
ZF motorsport LSD
18 spline shafts
6 linked
Also running 400bhp
Handles the power well with no issues
Attached Thumbnails Which axle to run 400 hp cossie in a mk2-15180a99-26a3-48a4-a4ea-9da1a436451d.jpeg
Old Apr 5, 2018 | 06:52 AM
smiley's Avatar
smiley
Thanks Tim best place to source those bits mate?
Old Apr 5, 2018 | 07:39 AM
costina's Avatar
costina
Live long and prosper!!
Search for lea123 on turbosport. He built a complete axle for someone I know wasn't cheap tho.
Or search for a 2.8 Capri axle or 3.0 which is an atlas. Then you can modify that to suit. ie cut down the axle tubes fit shorter shafts and diff etc.
Most parts can be bought new from Burton power.
Old Apr 5, 2018 | 07:48 AM
smiley's Avatar
smiley
Top man I'll pass that on mate
Old Apr 5, 2018 | 06:25 PM
timsrs's Avatar
timsrs
Squires at stoke on Trent
There often on the back page of classic ford magazine
They will have all the bits needed
Old Apr 5, 2018 | 09:52 PM
turnover's Avatar
turnover
As said a descent atlas is the preferred axle for that power,if your using road tyres will probably never break if built correctly
Old Apr 6, 2018 | 07:27 AM
smiley's Avatar
smiley
Thanks mate and to all who've replied that's that sorted appreciated
Old Apr 6, 2018 | 07:51 AM
davidfox280585's Avatar
davidfox280585
as others have said atlas all the way and definitely a 48.52 casing (baby) for a unarched mk2
i currently have a narrow 50" on mine with tarmac arches and 9j wheels
definitely go either zf motorsport lsd or a 3j nxg at the very least
cwp ratio id go with a 3.44 for a 400hp car.
all the advice others have given above is bang on the money
and definetly go 2 piece shafts 18t squires shafts in mine and took a beating definitely go to R.A.C.E (rally and competition equipment) stoke on trent for your gear.
some info for you here
http://www.classicfordmag.co.uk/wp-c...assic-ford.pdf
Old Apr 6, 2018 | 08:11 AM
smiley's Avatar
smiley
Thanks David will past that on
Old Apr 7, 2018 | 10:06 AM
cosmatt's Avatar
cosmatt
Squires axles are up there with the very best. I run mk1 unarched on english axle still. Uprated halfshafts,3.54 steel lsd. T34 on greens and has been for 3 yrs now. Only running 7 x 13" wheels though with 175/50s
tkracing
Feb 8, 2015 08:59 PM
BM507
Nov 23, 2011 07:42 PM
BM507
14
May 26, 2011 04:47 PM
cossiedave
Jun 30, 2009 11:00 PM
bazza
Ford Classics & Vintage
May 21, 2004 09:46 AM
