modine oil seals 4x4 sapphire
Old Apr 1, 2018 | 08:08 PM
ianbobo's Avatar
ianbobo
oohmamama
Default modine oil seals 4x4 sapphire
Hi guys, got a couple of questions for you to answer please;
1-is the oil filter arm to modine seal of the same size as that of the oil filter ?
2- burton power has got YB SC767 modine seal. Is this suitable to fit on each side of the modine, i.e. modine to block and modine to oil filter arm? Are both seals of the same size ?
3- there appears to be a copper sealing washer in between the oil filter arm and the closed ended nut holding the assembly in place over the modine, am I right? Should I replace this washer when reassembling back in place?
4- Is there any other seal inside I should be aware of and replace while the unit is out on the work bench?
5- Can you recommend someone where to purchase all the seals involved in the modine assembly?
Thanking you in advance for your kind help .
Old Apr 3, 2018 | 07:12 PM
The Youth.'s Avatar
The Youth.
the seal you need for the nut on the end is this one
https://ssli.ebayimg.com/images/g/YX...-s-/s-l640.jpg
not sure on the other 2 seals I have a feeling there slightly different thickness, I'd have to check my spares
Steve
Old Apr 16, 2018 | 08:25 AM
in2k's Avatar
in2k
Default modine.
still available from ford except one i think.
rsguy
Apr 21, 2013 07:30 PM
cossiedad
Feb 25, 2011 07:18 PM
Richie.
Oct 28, 2010 08:48 PM
Rippers
11
Aug 10, 2006 08:33 PM
