Roof aerial
Old 29-03-2018, 09:15 PM
qed296
qed296's Avatar
Default Roof aerial
How do folks.....
Now unfortunately my sapphire's roof has in the past had a aerial mounted on the rear of the roof.
The one fitted has been removed and the hole left had been covered with a modern "shark fin"
styled item.
Not very infitting with the original look I'm after, so it's now off awaiting a suitable replacement.
Was there ever one fitted by Ford's to the roof??
Pictures of what's been fitted by you guys or previous owners would help or any suggestions.
Old 29-03-2018, 09:46 PM
cossynut2
cossynut2's Avatar
As far as I am aware Saffs front windscreen has an in-built aerial, never seen a roof mounted one and I am glad you took the BMW style one off your roof, it looked horrendous!!
Had my 2wd Saff for 23 years, never had a roof aerial.
Old 29-03-2018, 10:01 PM
qed296
qed296's Avatar
I did wonder, I've been through Google and the data base on here and not found one picture.
What you say about the windscreen aerial is interesting as the radio won't pick up any signal but is connected to a lead
but what that goes to is now in question.
thanks
Old 30-03-2018, 08:28 AM
cossynut2
cossynut2's Avatar
thanks
Maybe there was a problem with the one in the windscreen and as a replacement one is expensive and not that easy to get the previous owner opted for the cheaper in roof aerial?
Old 30-03-2018, 11:03 AM
martysmartie
martysmartie's Avatar
thanks
The amplifier should be the first thing you check (beneath the back window) it should have an ignition switched live.
The first Saph's (non Cosworth) had the aerial on the offside rear wing.
The rear window contains the aerial, a good idea which was done to prevent vandalism.
Others have copied what Ford done 30 years ago.
Martin
Old 30-03-2018, 11:31 AM
qed296
qed296's Avatar
Thanks Martin, not noticed any sort of amp in the boot area....what's the exact location please.
Old 30-03-2018, 11:50 AM
Mad_Mat
New Owner
Mad_Mat's Avatar
This is the amp thingy you should have https://www.ebay.co.uk/itm/Ford-Sier...MAAOSwtoNalDFd
Old 30-03-2018, 12:43 PM
4x4kiwi
4x4kiwi's Avatar
Do 4x4's also have this amplifier as I have never noticed it in the near 20 years I have owned my car. (interestingly my signal also appears to be fairly weak) I would also be interested in a photo of the exact location. Thanks David
Old 30-03-2018, 04:21 PM
costina
Live long and prosper!!
costina's Avatar
Amplifier is located behind the rear shelf in a central position and is green in colour from memory.
No saffs came with roof antennas unless it was a cop car.
what about a focus base and aerial?
might look ok.
Old 30-03-2018, 04:34 PM
qed296
qed296's Avatar
So many options but if I get it wrong it will stand out like a sore thumb.
I have a ecos one somewhere complete so will have a look at that.
cheers
Old 30-03-2018, 06:01 PM
cossynut2
cossynut2's Avatar
Martin
I always thought it was in the front windscreen. I was told that is why the front windscreen is an expensive item to replace.
Old 30-03-2018, 07:01 PM
costina
costina's Avatar
I paid 160quid tor a Pilkington heated front screen fitted last year.
joys of being in the trade an knowing people.
saff aerial is always in the rear screen.
Old 30-03-2018, 08:54 PM
qed296
qed296's Avatar
Is it the green box, couple of wires coming out of it....
Old 30-03-2018, 10:14 PM
cossynut2
cossynut2's Avatar
So if the rear window that has the radio aerial built into gets broken is that expensive?
Old 31-03-2018, 10:57 AM
costina
costina's Avatar
yes it is.
Old 31-03-2018, 11:00 AM
costina
costina's Avatar
I would say it's more money due to the fact not many rear screens suffer like the front hence limited production runs equals more cost.
make sure if you guys ever need a rear screen it is the correct style.
From memory there must be at least 3 types.
Old 31-03-2018, 11:03 AM
costina
costina's Avatar
Qed your screen looks like it don't have the aerial in it.
will dig a pic out of mine to show difference.
Old 31-03-2018, 11:07 AM
costina
costina's Avatar
Notice the copper strip along the bottom you don' have this. That's the aerial.
Old 31-03-2018, 11:48 AM
martysmartie
You were told wrong. The front screen is expensive, simply due to it being heated.
Martin
Old 31-03-2018, 01:36 PM
cossynut2
cossynut2's Avatar
Looking at his photo again I think you are right, the original rear screen has been changed to one without an inbuilt aerial. Just looked at mine again.
Easy to spot if its got one.
Old 31-03-2018, 04:42 PM
martysmartie
Ignore.
Old 31-03-2018, 05:03 PM
qed296
qed296's Avatar
Good spot....only piece of glass not engraved as well.
Thanks for the info....got the amp so must have been broken at some point.
Old 31-03-2018, 05:36 PM
martysmartie
Well spotted
Martin
Old 01-04-2018, 09:27 AM
cossynut2
cossynut2's Avatar
If you don't want another roof aerial looks like a new ( or good used ) rear
Windscreen is the only answer. Wonder why when the original one got broken the owner did'nt insist on the correct one being fitted?
Old 01-04-2018, 10:06 AM
qed296
qed296's Avatar
Thing is I've now got a 10mm hole in my roof.
I've dug 2 aerials out to choice from, I think I'll be getting it plated and the roof painted anyway after summer.
The bee sting style is a smaller version off what you see on mk4 golfs and corsa c's...not sure where I got that from....
what do you think??
Old 01-04-2018, 04:04 PM
cossynut2
cossynut2's Avatar
Its your call but personally neither would be going on my Saff, I would be getting the hole plated and roof re-painted if funds allow.
Old 01-04-2018, 04:31 PM
qed296
qed296's Avatar
That's on the cards for sure but I thik id like to have the bonnet and front bumper done as well.
Its only a temporary measure, I do have some gommets I could use....
Old 01-04-2018, 04:34 PM
costina
costina's Avatar
I think it will have to be the escos one.
For now anyway.
Old 01-04-2018, 06:11 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Get the hole welded up then fit one of them digital ones that sticks to to the top corner of the windscreen
Old 08-04-2018, 07:20 PM
domink_goodfellow
domink_goodfellow's Avatar
Mine also unfortunately has a roof aeriel fitted, I can only assume this was done for a mobile phone as the holes are in the dash where the phone would have gone. I’m also going down the route where I will have to have it plated & painted.
Old 15-04-2018, 09:32 AM
iansoutham
OCD Victim
iansoutham's Avatar
Just for reference, the heated element is the aerial. The banding round the edge that you can see is on all versions.
on the pre Jan 1990 models it was visible, Ford just moved it when the face lifted the car in 1990.
if you go to the amp box under the shelf trim, the wires go straight from that to the window element connections. I would check the small feed wire to the amplifier as that is what powers the aerial part up. It is normally red/white and is also in the back of the radio. If this is good, most likely the amplifier box is dead. Even if some of the heated elements are not working on the window, there is still a circuit for the aerial.
Old 15-04-2018, 09:44 AM
steppy
steppy's Avatar
The 90s bee sting aerial is a winner for me, in fitting with the cars era when everyone was fitting them to their cars
I have one on my 3 door (rep) due to wanting the car to look symmetrical i think the oe ford aerial location looks odd
Old 15-04-2018, 04:24 PM
cossynut2
cossynut2's Avatar
I have been to lots of shows and never seen a Sapphire Cosworth with a bee sting aerial fitted. To me it would look wrong and spoil the cars look.
Old 15-04-2018, 04:26 PM
qed296
qed296's Avatar
Fitted the esc one for now...
Old 15-04-2018, 08:04 PM
4x4kiwi
4x4kiwi's Avatar
I wonder if Martin (Martysmartie) or Ian (Iansoutham) or anyone else for that matter, can confirm when the red/white wire (30-29 on the schematic) is supposed to be live. Martin mentioned that it is an ignition switched live, but I am wondering why it is supplied via the radio and not just switched via the ignition. My thoughts are that it is possibly only live when the radio (as opposed to CD etc) is on perhaps like the electric aerial drive feed they used to put out on stereos. My car (1990 4x4) had had a different head unit fitted before I purchased it 18 years ago, and over the weekend I was fitting a different unit and noticed the red/white wire is not connected at all. Although I haven't checked at the amplifier yet, I am assuming this is therefor unpowered, which would account for my weak signal mentioned in a post further up. Interestingly the radio works perfectly well when there is a strong signal around, only breaking up a bit when I get close to home which is in a bit of a valley. I mention this because I wonder how many others have fitted a new head unit and only connected up the battery and ignition feeds and a ground, possibly the lighting feed (grey/yellow) if needed and not realised what the other wires were for. (aerial amp feed and alarm) I will attach the diagram again in case that helps. I had attached this and a couple of others related in another post by qed296 asking about his stereo wiring which can be found here. https://passionford.com/forum/techni...tion-help.html . Thanks David
File Type: pdf
Old 15-04-2018, 08:59 PM
costina
costina's Avatar
Ian you are correct the element is the aerial. And some windows have different styles of element as I stated.
David I would say yes it only comes on with the radio.
qed I guess you could hook it up and try.
Old 15-04-2018, 09:07 PM
qed296
qed296's Avatar
I'll drop the back seats tomorrow and have a look and get some pictures for reference.
Since my 1st post I've been out about and have had some radio but not much, must be getting some sort of signal.
This car did have a massive sound system in it when I bought it which has been removed.
I wonder if somethings not as it should be with the wiring.......so many questions....
Old 16-04-2018, 10:27 AM
martysmartie
Ok, so he does have the correct screen, therefore back to my original suggestion of checking the amplifier.
I guessed it would be from the ignition radio feed, but from the diagram it appears it's an actual output from the head unit, as you say.
OP should check whether there is power in the first instance and then can troubleshoot accordingly.
Martin
maltablue
19-07-2013 05:36 AM
Martin-Hadland
21
16-03-2009 05:40 PM
AlexD
Ford Escort RS Cosworth
04-06-2007 06:20 AM
Gra
31-10-2005 08:06 PM
Quick Reply: Roof aerial
