Car goes lean when fans come on
Hi all - I was wondering if anyone can shed some light on my situation. My 3 door gets lean when the fans and or any heavy electrical load comes in.
It can be idling at afr 13.8 and when the fans kick in it will lean out to 15.8 - 16 afr and start to hunt! Thats over 2 whole units diff! Is this normal? It will return to 13.8 once fans shut off.
Thanks for any info.
Best.
Tim.
Best.
Tim.
Thanks for replies - the voltage is good underload 13.2Volts fans on. I don't think its a earthing issue either as loom is new. Its a weird one , I wonder if its a voltage compensation issue in the map!
Thanks for input.
Tim.
Thanks for input.
Tim.
I believe this may be caused by voltage drop at the ECU.
Are your fans rewired?
The issue is the fusible links (which supply the overloaded fuse box) build resistance, so coupled with a high electrical demand, results in voltage drop.
Martin
Martin
As above also rewire the fans so they are not connected to fuse box.
Replace battery to alternator cable really helps.
BUT also fit an upgraded ground cable from battery to chassis.
Tbh fans only come on while in traffic at idle so it is not too much of an issue imo.
As I say the fans should be rewired, an added advantage of doing this is it alleviates the load on the fuse box.
The fusible links build resistance which results in voltage drop, exasperated with load.
One thing that can happen is the ECU/injectors have a different voltage, which can cause issues. For example, @ WOT the injectors could slow down, leading to a potential meltdown.
Martin
Martin
Hi all - Thanks for all the input. The fans have been rewired running a separate feed. Also the loom is new and the injectors run an independent feed/relay system eliminating voltage drop at high boost. The fans are relatively new and draw 8amps. Alternator new pos cable and a string of unrated earthing points there is Zero differencial.
Its interesting!
Oh car is not in the UK or I would have been to see stu quite a while ago! Took me forever hunting down a misfire @24psi. Replaced all the usual bits over a period of a couple of years then oil consumption started rising. So took the engine apart and found the inner valve spring on number 4 exhaust broken and a completely missing the stem seal.
valve bounce/oil consumption!! job done.
Thanks all
Tim
Its interesting!
Thanks all
Tim
As the fans and electrical current grows the load on the alternator increases which in turn increases the load on the engine,
This causes the Ecu to reference a different load cell in the fuel table. Once its emulated you can watch the trace move when the fans cut in.
Its more than likely because the load cell it references under load is lean,half an hour on an emulator would allow you to iron out the load cells around idle speed to ensure the afr remains stable and this will usually cure it.
The areas in the fuel table just above idle can be tricky to reference but I find its Vital to reach them while live mapping to catch issues like this.
voltage at the Ecu is important, as is voltage to the battery.so worth checking what you have at the battery and at pin 20 with/without the fans
Its interesting!
Thanks all
Tim
Its interesting!
Thanks all
Tim
People worry about voltage on these cars too much, as long as it's not lean up the top I don't see there is an issue.
Otherwise you would end up rewiring most the car.
Martin
The voltage is pretty critical, the age old YB issue we see is at high RPM with lots of boost the Turbo is at its hottest, cooking the Alternator. This is the same time you are demanding optimum fuel delivery, fuel pump voltage, injector speed, coil voltage, so things go bad quite quickly.
I aim to keep the ECU at 14-14.2 under all driving conditions, so coil voltages, injector speed etc remains stable. I commonly see ECU voltage down to under 11v!
If you have 22ms to open and close and injector its critical they remain at optimum voltage for speed, so the injector open time can be optimised, especially on something with fuel limited tunes like T34 803s.
The load site issue isnt really a problem, it just means the map needs a little work, modern fans etc draw less current so the load on the engine is less, so can stop the issue, but the lean load cell still exists, just doesn't get referenced. If the load cells referenced are AFR stable compared to idle you wouldn't even notice the jump in sites.
Cars that are leaner at idle suffer more from moving load cells under slight load than those that are richer.
When we started doing the Alternator to battery cables, we were finding even the Electric windows were operating faster, so its crazy really on the effect it has on the whole car to optimise the battery voltage, after 30 years the wiring is not in good order on most.
hi - thanks for input . I think you are right re lean loaded cell. The battery voltage is 14.2volts, the loom is new and one of yours so imagine the voltage at the ecu is ok. (Don't really want to take ecu plug apart as it's lovely.
It is not lean at the topend the problem I have had is the leaning out on fan operation. I have by luck a chip (One of five) that does not have this leaning fan problem, its quite amazing really it idles @ 14.5 afr see 12.3 till 19psi till 6000 rpm then dumps more fuel in till 7000rpm @11.9afr.
Its been tested for det - temps etc - I don,t think you could get much better with a live map!!!
Happy days really.
Tim.
Happy days really.
Tim.
Happy days really.
Tim.
Happy days really.
Tim.
It wouldn't do any harm, it's simply a case of probing between pin 20 and earth.
You could also measure the voltage @ the injectors by back probing them.
Martin
nickywarwick
16
Jun 23, 2009 10:07 PM
Antti O
Apr 21, 2008 02:31 PM
SapphyMike
16
Sep 16, 2005 11:15 AM
abdr500
Mar 22, 2005 06:52 PM
