Heaters not heating up?
Mk6 fiesta
If the fan is set to low speeds there is, eventually, some warm air, but other than that it's dead cold
There's water in the system, the engine temperature is normal on the gauge, is the matrix blocked or is there something else?
Sounds like a blocked matrix, can you feel the pipes on the back of the block going through the bulkhead? You might be able to back flush it with a hose or try some cooling system flush?
Turns out it was the pipe to the heater matrix
Because it failed last night and dumped all the coolant out into the floor
My next day off isn't until Tuesday so I guess I'll have a look at it then
i changed it on my mk4.5, it was easy
but this pipe on the mk6.5 was an utter bastard
apparently it's so common that when it split the aa guy had just come from the same issue on another car and had used the one he normally carries with him
but yes, it's air box off, coil pack out of the way, various pipes and stuff to move out of the way and then you can get to the clips
you then have to contort your arms and hands and fingers to get to the quick release fitting on the heater matrix and it's off
took about 5 minutes to put it back together again and another 5 minutes to get it up to temperature but it took around 40 minutes of buggering about to get to that stage in the first place
i've got a picture somewhere but it looks like it had been leaking for some time as there was an extra jubilee clip on it that wasn't on the replacement pipe and it was all pink and furry where it had been leaking from before
i've had the car for 4 years now so it's been a problem for at least that length of time
tony_turbo
18
Dec 29, 2007 08:38 PM
stusfesta
Feb 12, 2006 07:41 PM
stusfesta
Feb 11, 2006 07:00 PM
