Fiesta engine conversion
Old Mar 12, 2018 | 10:14 PM
steveo135's Avatar
steveo135
Default Fiesta engine conversion
Firstly apologies if this has been asked already before.
I have a mk3 fiesta van with a 1600 cvh. I've been offered a mk3 mondeo with a 2.0 zetec engine in. The question is will it go in the fiesta? Ideally I'm wanting to put it in as it is, I don't want to start changing management or run carbs.
Do I require anything else......
Thanks in advance
Steve
Old Mar 13, 2018 | 07:56 AM
big_wasa's Avatar
big_wasa
Mk3 mondeo will be the Duratec. The zetec will be the model / trim spec.
Still a very good engine.
Old Mar 13, 2018 | 07:58 AM
oldford's Avatar
oldford
You DO need the engine management system from the Mondeo.
If you don't want to use that, then don't buy the engine.
Old Mar 13, 2018 | 11:56 AM
big_wasa's Avatar
big_wasa
You will be very much on your own with the electronics side of the conversion. It's pretty unusual to keep the oem injection due to the power restriction and the complexity.
It can be done and I could give you the info on a proper zetec but you will need to be very confident with auto electrics to to it.
I am just about to start a rwd st220 engine project on its own ecu but I have done dozens of other Ford's on oem injection.
perry3188
Apr 14, 2013 03:56 PM
bonus_boy
110
Feb 20, 2008 05:00 PM
16
Jan 9, 2006 11:34 AM
ben11
Apr 12, 2005 07:21 PM
