Rear camber shims.
Old Mar 3, 2018 | 03:36 PM
Default Rear camber shims.
Are these shims worth fitting? I've heard they help to prevent tyre wear. Do they help with the handling??
Old Mar 3, 2018 | 04:39 PM
Marc sierra's Avatar
Marc sierra
They could help, but it depends on what your camber currently is. Toe is also really important for handling and tyre wear.
Old Mar 3, 2018 | 06:09 PM
It's just a standard cossie rear axle with standard good condition bushes in the arms and poly bushes beam and diff mount.
Old Mar 3, 2018 | 06:25 PM
1374lee's Avatar
1374lee
As I said before when you asked Glenn a must to correct the negative camber as much as possible, it's the best you will get without fitting an adjustable beam.
Just had mine fitted.These are what I purchased.
http://www.ebay.co.uk/itm/Ford-Sierr...53.m1438.l2649
Thanks. Lee.
Old Mar 3, 2018 | 06:27 PM
Marc sierra
The camber depends mostly on the ride height. If it's not very low you don't need the camber shims. I would try to get the camber close to -1.5 degrees. In the past I have done that by putting large washers in between the bearing carrier and arm. That way you can tune it better than with just a single shim.
Old Mar 3, 2018 | 09:00 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
I fitted the shims on my XR4x4 as I am running -30 mm springs. Tyre wear is now even where it used to scrub out the inner edges of the tyres.
Old Mar 4, 2018 | 07:35 AM
Thanks for that info. Nice and simple like me lol.
Old Mar 4, 2018 | 09:14 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Worth a try Glenn if you don’t fancy paying out for a beam. I do wonder when you fit these are they machined around the bolt holes on the shim so the bolt head bolts up to a flat surface?
Old Mar 4, 2018 | 10:26 AM
timsrs's Avatar
timsrs
I’ve got some anti camber shims
Not used
Ł30 delivered
Old Mar 4, 2018 | 10:35 AM
MalZon's Avatar
MalZon
I got on mine. If you lowered you need.. I got 2,7° camber i rear and 2,5° in front. And i got som lowered.
Regards/Jonas
Old Mar 4, 2018 | 02:22 PM
I've always thought that the bolts might sit at a funny angle.
Old Mar 4, 2018 | 02:23 PM
Not used
Ł30 delivered
PMed mate.
Old Mar 4, 2018 | 02:25 PM
ajamesc's Avatar
ajamesc
Not hard to find someone with a milling machine to mill the hub carrier out a little unless you can find some wedge shaped washers
Old Mar 4, 2018 | 02:31 PM
costina's Avatar
costina
Live long and prosper!!
That' exactly what I have done when I ditched the back plates to for 4x4 rear brakes.
I am on std ride height with std springs and konis set to mid. Straight line grip isn't bad and tyre wear is good.
Lee will agree it hooks up well.
Old Mar 4, 2018 | 02:33 PM
costina's Avatar
costina
You can buy wedge washers for M10 bolts on eBay for peanuts.
As Marc will say it makes very little difference on bolt mounting.
Old Mar 4, 2018 | 02:35 PM
costina's Avatar
costina
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.de%2Fulk%2Fitm%2F391 083741542
Old Mar 4, 2018 | 03:09 PM
ajamesc's Avatar
ajamesc
Personally I’d still like the bolt to torque up on a flat surface rather than a hub carrier sat at a slight angle. If it’s your your car and it’s apart anyway you may as well get the wedge washer and do it properly
Old Mar 4, 2018 | 03:23 PM
costina's Avatar
costina
Andy we are talking very minimal amount I personally am fine with it. And all chamber shims are not supplied with wedge washers.
Hey at least they are bolted on with original bolts unlike the Buffty boys who use stainless bolts😂
Old Mar 4, 2018 | 03:27 PM
ajamesc's Avatar
ajamesc
I’m just a funny cunt lol getting to picky with older age
Old Mar 4, 2018 | 03:44 PM
1374lee's Avatar
1374lee
Oh yes indeed Paul..lol.
CheeRS.Lee.
Old Mar 4, 2018 | 03:50 PM
costina's Avatar
costina
Lmfao.
The only way thinking about it being perfect as the hubs have round spot faces on them, Is to mount them on a mill with the said shim under it and re spot face the 4 mounting holes.
seems like a big faff imo.
Old Mar 4, 2018 | 04:48 PM
Can you repost that link matey.
I was thinking about sorting some washers out for the bolts.
Old Mar 4, 2018 | 06:44 PM
costina's Avatar
costina
Its not working for me Glenn as I do everything on my phone.
just search eBay for M10 wedge washers. Bit tbh I don't think they will work as the hub has counter bored faces.
Old Mar 5, 2018 | 08:42 AM
Jules44's Avatar
Jules44
10 Year Member
https://www.ebay.co.uk/itm/M10-Taper...xINcVMLF0g-22w
Old Mar 5, 2018 | 08:56 AM
nixon_2wd's Avatar
nixon_2wd
Better option:
https://www.elesa-ganter.com/product...eries/din-6319
Spherical washers.
https://www.ebay.co.uk/itm/GRAINGER-...cAAOSwopRYduSr
Old Mar 5, 2018 | 10:18 AM
Adam-M's Avatar
Adam-M
But when you use both halves together you end up back at square one do you not?
Old Mar 5, 2018 | 11:16 AM
Jules44's Avatar
Jules44
10 Year Member
You can angle them like setting the brakes up on a mountain bike
Old Mar 5, 2018 | 11:58 AM
Marc sierra
If you are going to use wedged washers the angle on the washer needs to be the same as the angle on the camber shims, otherwise you might make an even bigger angle the other way.
I'm not sure how much camber the camber shims actually correct, but I think correcting 1 degree of camber will in most cases be enough. If you correct 1 degree of camber with shims or washers, the difference over a bolt head of 2 cm wide is only 0.35 mm. So your wedged washer should be 0.35 mm thicker on one side than on the other. Personally I don't think it will be an issue just putting the normal bolts back in without any special wedged washers. And I have driven my car like that for probably 50k to 100k miles.
Old Mar 5, 2018 | 07:13 PM
Well I will see what the crack is with the shims when I get them and get them fitted
Old Mar 5, 2018 | 07:17 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
To reduce the rear negative camber you can quite simply slot the inner semi trail arm inner pivot mounting point upward.
Old Mar 5, 2018 | 07:22 PM
1374lee's Avatar
1374lee
Ah the voice of much experience Tony, very interesting info.
CheeRS.Lee.
Old Mar 5, 2018 | 08:07 PM
steppy's Avatar
steppy
a few pals of mine at festival park ran around in 2wd cossies like this back in the day
lee2cossies
17
Mar 21, 2010 12:24 AM
baz walton
50
Mar 13, 2010 11:40 AM
massivewangers
Feb 25, 2010 09:10 PM
joffy
May 1, 2008 09:55 AM
zetec69
Dec 31, 2006 11:37 AM
