Rear camber shims.
As I said before when you asked Glenn a must to correct the negative camber as much as possible, it's the best you will get without fitting an adjustable beam.
Just had mine fitted.These are what I purchased.
http://www.ebay.co.uk/itm/Ford-Sierr...53.m1438.l2649
Thanks. Lee.
Thanks. Lee.
Glenn_ (04-03-2018)
The camber depends mostly on the ride height. If it's not very low you don't need the camber shims. I would try to get the camber close to -1.5 degrees. In the past I have done that by putting large washers in between the bearing carrier and arm. That way you can tune it better than with just a single shim.
cossie fan (unluckerly)
Worth a try Glenn if you don’t fancy paying out for a beam. I do wonder when you fit these are they machined around the bolt holes on the shim so the bolt head bolts up to a flat surface?
Glenn_ (04-03-2018)
Live long and prosper!!
I am on std ride height with std springs and konis set to mid. Straight line grip isn't bad and tyre wear is good.
Lee will agree it hooks up well.
Personally Id still like the bolt to torque up on a flat surface rather than a hub carrier sat at a slight angle. If its your your car and its apart anyway you may as well get the wedge washer and do it properly
Im just a funny cunt lol getting to picky with older age
Better option:
https://www.elesa-ganter.com/product...eries/din-6319
Spherical washers.
https://www.ebay.co.uk/itm/GRAINGER-...cAAOSwopRYduSr
Spherical washers.
Better option:
Spherical washers.
Spherical washers.
If you are going to use wedged washers the angle on the washer needs to be the same as the angle on the camber shims, otherwise you might make an even bigger angle the other way.
I'm not sure how much camber the camber shims actually correct, but I think correcting 1 degree of camber will in most cases be enough. If you correct 1 degree of camber with shims or washers, the difference over a bolt head of 2 cm wide is only 0.35 mm. So your wedged washer should be 0.35 mm thicker on one side than on the other. Personally I don't think it will be an issue just putting the normal bolts back in without any special wedged washers. And I have driven my car like that for probably 50k to 100k miles.
lee2cossies
17
21-03-2010 12:24 AM
massivewangers
25-02-2010 09:10 PM
