Diff ratios. MK1 ESCORT PROJECT.
Old Feb 27, 2018 | 11:13 AM
Ronnie-rsmk1's Avatar
Ronnie-rsmk1
Default Diff ratios. MK1 ESCORT PROJECT.
Hi all. Im planning and collecting Parts for a Escort MK1 RS2000 replica. Its sitting on a Capri Rear Axle, so i was told! My query is it appears to have a diff ratio of 2.1?? Yes ive checked and double checked ...2.1 yes one wheel sitting on Ground ! Can anyone help with any information on this ratio. Im planning a 3.54.. Ronnie
Old Feb 27, 2018 | 07:30 PM
turbo m's Avatar
turbo m
2.1 would be high geared???
I know 4'.11 are low for escorts etc quick off the line but rev like fook.
Old Feb 27, 2018 | 07:53 PM
Ronnie-rsmk1
Default Diff ratios
ye when i told my mate it was 2.1 his reaction was " really keep it" . Very quick of the mark he recons. ts worth leaving i guess and if no good mid range ,top end then i'll source a 3.49.
Old Feb 27, 2018 | 09:25 PM
turnover's Avatar
turnover
2:1 would make it too long geared,your calculations must be wrong,3:75 is most popular and 4:1,higher the number the faster you will go through the gears ,but will make your top speed slower and obviously cruising speeds higher revs
Old Feb 28, 2018 | 02:23 PM
davidfox280585's Avatar
davidfox280585
more like lazy off the mark.
The atlas came in a variety of different cwp ratios and best suited to what power you will run
ideally an atlas a 3.75 is a good all round road diff.
you need to mark the pinion cup and a road wheel and spin to get your ratio if its a johnny oner get a friend to hold the other wheel still
Old Feb 28, 2018 | 02:54 PM
Ronnie-rsmk1
Default Diff ratio
cheers for that .. I must have picked up wrong because he would deffo know the score on that. Your comment made me do some reading up on the sudject and your spot on. However im still lost as to why the diff has this ratio ! Im planning on type 9 gear box and a cossie spec engine around 250 bhp. Whats your thoughts pls and who or why fit a 2.1 diff ratio ( defo 2.1) cheers Ronnie
Old Feb 28, 2018 | 02:56 PM
Ronnie-rsmk1
Default Diff ratio
Old Mar 1, 2018 | 08:34 AM
lee2cossies's Avatar
lee2cossies
Iv never heard of a 2:1 diff before, but anything is possible as the atlas was fitted too a variety of cars and vans here and other countries. as already said 3;75 is the most popular, I run a 3;75 in my capri with a t5 box, I wouldn't run a type 9 at the rear of a cosworth though wont last long.
Old Mar 1, 2018 | 09:19 AM
turbotrev's Avatar
turbotrev
I’ve necer heard of a 2:1 diff either, that would be mega high geared
Cheers Paul
Old Mar 1, 2018 | 09:54 AM
GVK.'s Avatar
GVK.
Has it still got a tag on one of the diff bolts, some old Fords had a small metal tag on with the diff ratio.
Never heard of a 2:1
Old Mar 1, 2018 | 07:40 PM
Ronnie-rsmk1
hi lee, what gear box would you suggest if i go the cossie spec engine route..and 3.5 - 3.7 diff ratio .for a bit of an idea what im after is what i guess they are calling a sleeper..im experienced with bodywork etc so will go to town on the shell, all New rs spec shell . I'll stick with gt wings but want to go to town on the mechanics. Your thoughts pls! Regards Ronnie
bennydg
Sep 10, 2007 10:39 AM
bigal1978
Feb 19, 2006 03:54 PM
Stavros
16
Aug 3, 2005 01:16 PM
Sean Bicknell
Aug 29, 2004 06:55 PM
CosRush
Jan 18, 2004 12:04 PM
